adjusting preload FXDWG3
Old Nov 15, 2007 | 02:46 PM
skr8pn's Avatar
skr8pn
Default adjusting preload FXDWG3
I asked this over at the general suspension area but didn't exactly get what I was thinking. My left shock is stupid how tight it is and I can't get it to move to increase the preload. The previous owner has it slammed down. I know they make a spanner but isn't that more for the standard shocks on most models. Can you use them on the shock on the DWG3 models? I'd had to scratch them. Also, any way to adjust the valving once you get the preload adjusted?
Old Nov 15, 2007 | 06:08 PM
nidan's Avatar
nidan
Default RE: adjusting preload FXDWG3
My FXDWG3 had the standard FOX oem shocks and you could adjust it by hand , no spanner needed , and it was the only adjustment
Old Nov 15, 2007 | 06:25 PM
skr8pn's Avatar
skr8pn
They are hand adjustable but I absolutly can not get it to move. I even put a little bit of WD-40 on the threads to let it setsome and hopefully loosen it up.I read some where that somebody used a strap wrench so thinking about trying that. Maybe sense they are FOX shocks I can find something specifically for them.
Old Nov 17, 2007 | 08:10 PM
skr8pn's Avatar
skr8pn
Ended up buying a set of $10 strap wrenches at Advance Auto Parts. Took a couple of time but that shock finally broke loose. Even then it took a couple of turns moving it down with the wrench to get it free enough to be able to move it by hand.
Now on to the brakes!....
BDA120R
Feb 25, 2015 05:41 PM
Columbanus' assistant
Shovelhead
Nov 24, 2013 11:27 PM
davbib
Jul 8, 2013 12:21 PM
marcparnes
Sep 8, 2011 01:59 AM
supermario
Feb 20, 2007 06:01 PM
