Cam Chain gone...
Old May 14, 2008 | 01:59 PM
toneman's Avatar
toneman
Default Cam Chain gone...
Well time for a new cam chain at 32540 miles....going to a gear drive with 510GCam Kit. Power Commander and high output oil pump. Not sure on new exhaust.Sorry to see my duals go but time for a 2 into 1to optimize performance. Undecided between D&D Fat Cats, or Vance & Hines. Any opinions?
Old May 15, 2008 | 11:12 PM
toneman's Avatar
toneman
Default RE: Cam Chain gone...
Goin to D and D 2 into 1 Fat Cats with my build out. Laidlaws in Baldwin Park, CA. is doin' the work...will post Dyno results upon completion....[sm=biker.gif]
Old May 15, 2008 | 11:57 PM
Hedog's Avatar
Hedog
Sounds like a plan, keep us posted....[sm=icon_cheers.gif]
Old May 24, 2008 | 09:23 AM
toneman's Avatar
toneman
Bike is back.Went with S&S 510 G cams,gear drive, D&D Fat Cats, Power Commander. During the timemy bike was in the shop I did alot of homework. Should had done that before I put her in the shop!. Anyway, I found out my 2004 103" had SE253 cams with a lift of 535. So my thought was more lift more power.My old 103"hadBassani slip ons, and the usual air cleaner and chip work.
I was apprehensive that I went too conservative.Maybe I should have went with 570's. Well I'm pleased with the results.Dyno was TQ 96.. HP 97, not bragging #'s but respectable. Dealer says I could use a compression release as there's a kick at start up, will wait on that.She pullsstrong from 2000 up to 5700. Pulls the front wheel going into 2nd and tries going into 3rd. The exhaust is louder thanmy Bassani....sweeeet. There's a considerable difference atidle.Although the cams have a shorter liftthey sound beefier. Of course they have different overall specs.You can hear the gear drive at idle but it's not annoying. I'm pleased with the results, but wonder what the numbers would have been with just the Fat Cats, Power Commander and tune. Well at least I'll never see those orange chips in my oil! Ifit stops raining here in So.Ca. I'll check out gas mileage this weekend andand overall performance.
Just can't stopthinking about those 570's....stay tuned.[sm=confused06.gif]
Old May 24, 2008 | 09:28 AM
bikerbehaviorist's Avatar
bikerbehaviorist
I put the gear driven 510 set up in my stage one 88" heritage and it was great, kicked ***!
Old May 25, 2008 | 08:01 AM
toneman's Avatar
toneman
Had a chance to ride Saturday. Very pleased with the set up. Will leave alone. New problem...need compression release. If I turn motor off I need to let her sit and cool off, lose pressure. If I don't the starter plates spin, and she coughs.It's like having 2 wives[sm=usa.gif]
slammed05fatty
Jun 9, 2014 09:52 AM
andrewhed
Dec 28, 2013 02:29 PM
RoadBurner69
Oct 8, 2012 02:04 AM
toneman
May 25, 2008 04:56 PM
Sleeps In Trees
Jul 8, 2006 09:40 AM
