SEUC DYNO NUMBERS
Old May 28, 2008 | 04:53 PM
mike70's Avatar
mike70
Default SEUC DYNO NUMBERS
...just got back from dynoing my 2008 seuc #'s were were pretty good 88hp and 106 torque. That's with Reinhart true duals se air cleaner and PCIII...unfortunately, my buddy whoowns a 2007 seuc spotted that his rear cylinder was spitting out oil as we were about to leave the dyno shop.[:@]
Old May 29, 2008 | 12:09 PM
dope_man_21's Avatar
dope_man_21
Default RE: SEUC DYNO NUMBERS
I don't know how much effect that the heavy breather had on my 2007 FXDSE, but my dyno numbers looked much better on the horse power and about the same on the torque, my numbers were 103.3 rear wheel horse power, at about 5500rpm, and 110.8 pounds feet of torque at 4800 rpm.
I have the Cobra Speedster Slash Cut pipes, the K&n Heavy Breather, and the Cobra FI2000r Tuner on my Engine.
[IMG]local://upfiles/47348/243B5FC202D64F45A82951845C1B4EF9.jpg[/IMG]
Old Jun 2, 2008 | 10:11 AM
seultra's Avatar
seultra
My '07 SE Ultra has had four exhaust systems counting the factory system as #1. Included: #2 Vance & Hines true duals w/flat ovals [:'(]. . . hated that noise! #3 Reverted to Rinehart true duals (hd'em on two previous dressers)& lost substantial torque but gainednice HP - although not very usable and sounded MUCH better ! Now (after cams, heads, pistons, etc.) #4 D&D Fat Cat 2-1.
WOW!! Torque, HP - usable with the torque where it belongs.Sound/tone/volume . . .[sm=smiley20.gif]!! Only 850 miles into the break-in with only AFR set but not optimally tuned.
Old Jun 2, 2008 | 10:24 AM
seultra's Avatar
seultra
DUH!! Totally forgot:
Baseline stock: 82.35HP / 98.76ft-lbs
V&H true duals w/ Flat Oval Mufflers, Arlen Ness Big Sucker & SERT: 87.28HP / 110.89ft-lbs
S&S 625G Cams, Rinehart true duals, & mufflers w/ standard baffles, Big Sucker & SERT:96.8 HP / 99.8ft-lbs
Heads/Pistons, SE Billet Cam Support Plate, Big Sucker, SERT D&D Fat Catno dyno tunejust set AFR) - approx 106HP / 108ft-lbs
Will know further after another 500 mile oil change and final dyno tune.
*** dyno confirms . . . Holy $h!t . . . serious FUN now~!
Old Jun 2, 2008 | 10:31 AM
sonic's Avatar
sonic
94 HP 117 torque for my SE dyna
Old Jun 2, 2008 | 08:42 PM
mike70's Avatar
mike70
...those are great #'s, can't understand why I was only able to fetch 88hp and 106torque...maybe it's the Canadian air!
Old Jun 3, 2008 | 03:41 PM
seultra's Avatar
seultra
With what mods? That torque is fat! Cams, heads, ?? Trusted dyno? Trusted dyno operator?
Old Jun 3, 2008 | 09:34 PM
dhudson's Avatar
dhudson
Stage IV
07' FXDSE 94.49 HP 111.30 Torque Vance and Hines Big Radius 2 into 2, Zippers element, and new SERT, 1350 miles and nowwith these few mods runs great.
Old Jun 3, 2008 | 10:51 PM
mike70's Avatar
mike70
...Reinhart true duals, a/c, and PCIII...thats it...dyno operator is well known and respected around this part of the world!
Old Jun 17, 2008 | 05:58 PM
rheiner's Avatar
rheiner
http://i4.photobucket.com/albums/y13...yno5232008.jpg
I'm getting 88 &amp\\; 105 on my 2008 SERK with Reinhart true duals, sert, and stage 1. What is the best way to improve from here?
