'08 FLHTCUSE Acceleration Problem
Old Aug 18, 2009 | 08:01 AM
jddrouin's Avatar
jddrouin
3rd Gear
Default '08 FLHTCUSE Acceleration Problem
All - Posting from the Middle East - I have an '08 FLHTCUSE (w/ the 113 CID engine, not the 110), that has very recently decided to turn into a dog when I accelerate hard.
The engine runs fine at idle and moderate acceleration, but when I open the throttle hard, it starts missing, obviously starved for either fuel or air.
I am looking for suggestions please, even the obvious ones. I do not have a lot of confidence in the mechanics over here to adequately diagnose / repair the problem.
Old Aug 18, 2009 | 06:13 PM
Shovelhead Bob's Avatar
Shovelhead Bob
What EFI management system are you using and what are the scan values of the TMAP, ET and are there any CEL's????
Benchtop diagnostics are a PITA without a bit more info....
Old Aug 19, 2009 | 03:51 AM
jddrouin's Avatar
jddrouin
3rd Gear
Default Additional Info
Bob - the dealer's facilities are somewhat limited (no dyno), but they tell me the significant trouble code is a 'lean fuel' reading for the rear cyclinder. From his inspection of the plugs, this is not the case. He's tried a different fuel map to see if that helped (didn't), so he's re-installed(?) the map for the 50mm intake and 113SE engine. The fuel pressure reads 60 psi, and though the air filter isn't super clean, neither is it near needing to be replaced. The 'cut-out' in acceleration happens consistently at or near 3,500 rpm.
I do not know if it is significant, but the problem(s) started after I had the bike parked inside for 5 weeks while back in the US.
Old Aug 19, 2009 | 10:36 AM
nj08SEUltra's Avatar
nj08SEUltra
Sounds somewhat different than a problem I experienced with my '08, but take a look at the problem I had: may give you some ideas. Good luck. http://www.cvoharley.com/smf/index.php?topic=37915.0
jthunder
Mar 15, 2015 11:53 AM
jddrouin
Aug 18, 2009 04:29 PM
kuleli
Sep 2, 2008 09:26 AM
Crazier Steve
Jun 13, 2008 03:16 PM
