2005 SE ElectraGlide
Old Feb 5, 2010 | 10:12 PM
royfrancis's Avatar
royfrancis
Stage II
Default 2005 SE ElectraGlide
Bought new in 2005 and have heard that the tension shoes on the cam chains have been known to wear. I have 47K miles and am wondering what signs to watch for and what is the best fix. It is covered on extended warranty until 02/11/11.
Old Feb 5, 2010 | 10:16 PM
GMbagger's Avatar
GMbagger
I would suggest upgrading the tensioners from your stock spring style, to the newer hydraulic style. That is when you go into the engine.
Old Feb 9, 2010 | 02:54 AM
LTBiker's Avatar
LTBiker
I'm picking up an '04 FLHTCSE with 14K miles; that has been one of my concerns as well. An indie I've done business with for over 20 years says I should replace the cam chain drive setup with the gear-drive setup, but that along with a new cam he recommends will run about $1800, more than I want to spend right off the bat. I imagine you can tell from the sound when the spring tensioners start going. I'll probably go with the hydraulic tensioners as previous poster suggested when the time comes.
Architect
11
Feb 17, 2014 03:40 PM
hdcyr
Jun 20, 2010 05:55 AM
buick455gs
Screamin Eagle CVO Models
Jan 1, 2008 11:58 AM
vernh59
Mar 12, 2007 02:11 PM
airjoe
Dec 4, 2006 06:08 PM
