What Dyno Results Can Be Expected
Old Jun 23, 2010 | 02:25 PM
hdnik's Avatar
hdnik
Default What Dyno Results Can Be Expected
I am having the bike Dyno Tuned Friday. Was hoping to get best guesses on what numbers i could expect so that i know whether to be satisfied that the tuning specialist has done the job for me or not. On the other hand i don't want unreal expectations and look foolish either.
Bike is 2010 SE Street Glide (FLHXSE), stock 110, SE heavy breather, V-H Dresser true duals (not power duals), Klockwerks Revolver Platinum Series 4" mufflers, SE Pro super Tuner.
Thanks in advance
Old Jun 23, 2010 | 03:10 PM
Mr. Wizard's Avatar
Mr. Wizard
Thanks in advance
My set up is a little different as I have the Fullsac X Pipe and the TTS.
Here is a dyno sheet that shows stock and after the tune.
Attached Thumbnails What Dyno Results Can Be Expected-2010-cvo-stage-i-x-pipe-vs-stock-2-.jpg
Old Jun 23, 2010 | 04:13 PM
hdnik's Avatar
hdnik
Mr. Wizard Thank you for your reply. Unfortunately for me, and for some reason only known to the administrator of this forum, i cannot access your JPG file.
Can you type the results for me.
Old Jun 23, 2010 | 05:20 PM
Mr. Wizard's Avatar
Mr. Wizard
I think you need 5 or more post before you can see pictures.
Stock 83.60 HP 102.27 TQ
Tune 98.61 HP 113.53 TQ
Old Jun 23, 2010 | 07:43 PM
hdnik's Avatar
hdnik
excellent. i'd be very happy with similar results. thanx again
Old Jun 23, 2010 | 10:27 PM
bigmegina's Avatar
bigmegina
09 serg,catless headpipe,fuelpak,rhinehart slipons,97 hp,108 ft pounds tourqe.
Old Jun 24, 2010 | 08:16 PM
hdnik's Avatar
hdnik
Thank you all. Will post results after dyno friday
Old Jun 25, 2010 | 07:56 PM
2WheelGlider's Avatar
2WheelGlider
My dad just had similiar work done to his 2010 CVO UC and he got 97 and 111
Old Jun 27, 2010 | 12:53 PM
hdnik's Avatar
hdnik
Well they aren't the numbers I've seen here but I'm very satisfied. I don't have a stock base line as the mods were done before it was dyno'd; but naturally we have a base line with mods but before tuning.
At installation of the Heavy Breather/V-H true duals/Klockwerks the 110CVO-Heavy Breather-Race Exhaust map from Harley was uploaded with the SEPST. I knew it was a generic modified map, but had no idea how LEAN it was. Look at the Dyno... it hovered between 14.5 and 15.5 to 1 AFR. Cylinder Temps in the dyno room were a high of 296F front and 321F rear... using a laser heat thermometer gun. Also notice how bumpy the curves are! All of that was noticeable in the grip under hard acceleration.
After tuning temps dropped to 238 front and 259 rear. Over all a 10% increase in HP/Torque to 91.11/111.31... simply by tuning; and as you can see a considerablely smoother curve. Also torque curve starts peaking in down around 2800 - 3000 rmp rather than at 4000 rpm... far more useable I think. Decel pop is gone, throttle response is so much better...no lag or lumpiness at all...and I may be crazy but I think it sounds better too
I highly recommend a dyno tune if you do any mods. I'm a believer. For 190 bucks and 3 hours of your life, it's well worth the investment. Imagine if there was one part you could buy for $190 bucks that would give you that noticeable of an improvement... they wouldn't be able to keep them on the shelf!!
Old Jul 7, 2010 | 06:39 AM
Raza51's Avatar
Raza51
These results mirror mine I have a 10 SESG with Rush slip ons, and the Heavy breather, Power Commander...
I did it so I could feel comfy pulling my Timeout Camper....worked flawless
