Oil Light 2002 SE Road King
Old Sep 2, 2010 | 09:00 PM
jamesamcnair's Avatar
jamesamcnair
Stage III
Default Oil Light 2002 SE Road King
Recently the check oil light on my 2002 SE Road king has been coming on at idle. The oil level is more than half way between the add oil and full lines on the stick. When the engine is revved, the light goes off. Should I be concerned? I dont think this is normal. Any help?
Old Sep 2, 2010 | 09:53 PM
tmitchellof PG's Avatar
tmitchellof PG
I can't help as far as your oil light coming on.
I do know that it isn't because you keep the oil level midway between add and full.
What brand oil filter are you using?
Tom
Old Sep 2, 2010 | 11:39 PM
Mr. Lucky's Avatar
Mr. Lucky
Sounds like an oil pressure problem or your idle is too low. Actually, it's an oil pressure problem either way because if your idle is too low, so is your oil pressure. If your idle hasn't been set lower, you could try a higher flowing oil filter like Wix or Baldwin. If that doesn't fix it, you'd best have it looked at by a professional.
sluginxlt
EVO
Sep 25, 2016 10:21 PM
pjsonnentag
Oil Archive (no new posts)
Oct 12, 2012 09:13 AM
grantuk
EVO
20
Sep 28, 2010 08:59 PM
jemerick
Dec 12, 2008 09:36 AM
stonecold1224
Sep 13, 2007 06:45 PM
