Interfacing Fairing Mount GPS
Old Apr 7, 2012 | 06:48 PM
src's Avatar
src
1st Gear
Default Interfacing Fairing Mount GPS
Hi all,
This is my first time posting on this site. Just picked up my 2012 Street Glide CVO today. I had the fairing mounted GPS (with XM) installed. I had ordered the wiring harness that I thought was required to make the GPS/XM play through the radio speakers, but they told me that it doesn't work that way on the Street Glide. The only way they tell me it can interface and play through the speakers is through the AUX port on the front of the radio. Not what I expected. Has anyone been able to incorporate it inside the fairing without having the wire come out of the fairing and plug into the radio? Any help will be appreciated.
Thanks,
Steve
Old Apr 8, 2012 | 04:39 PM
crackers's Avatar
crackers
I had this on my ultra limited and I had aux put in the back of the radio. Did a lot of research and that's what I had to do
Old Apr 8, 2012 | 06:19 PM
src's Avatar
src
1st Gear
Hi crackers, Did u have H.D. do it or a radio shop.
Old Apr 8, 2012 | 07:24 PM
crackers's Avatar
crackers
Radio shop
Old Apr 9, 2012 | 07:42 PM
Mr. Wizard's Avatar
Mr. Wizard
It can be done yourself as well. That's the way I did it.
When you install a AUX jack and rework the radio you can still use the front AUX port but if you don't have anything plugged into the front port you can still use the handlebar controls to stop on the AUX setting.
This link may help but you also need the NIM installed. Maybe your dealer already installed one when he did your wire harness rewire.
http://freedownload.is/doc/here-goes-5905308.html
In this link is says to cut a solder trace on page 5 and 6... DON'T DO IT. Just remove the transducer shown on page 6. That's all you need.
Old Apr 9, 2012 | 07:49 PM
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by crackers
Radio shop
Crackers... Got to needle you a bit about sending off your radio. It's way too easy to do it yourself. But... I know you are old and your eye sight is going bad. That transducer is hardly bigger than a grain of sand and you would have to use your HUGE reading glasses..
Old Apr 10, 2012 | 06:45 PM
src's Avatar
src
1st Gear
Hi Wizard the dealer did not do a thing but run a wire over the front of the fairing and take my 800.00$ and said can not do it. that the way it is!
Old Apr 10, 2012 | 07:35 PM
Mr. Wizard's Avatar
Mr. Wizard
Click Here and read all about what needs to be done.
800 bucks huh... whewwwwwww
-wiz
Old Apr 10, 2012 | 09:50 PM
gaither2004's Avatar
gaither2004
Not lucky enough to have the CVO but did get the Ultra Limited. I had my GPS mounted to the fairing and the wiring harness that was recommended by the dealership. The sound all comes through the speakers without anything pluged into the front of the radio. The wiring harness is in the 2012 catalog.
Old Apr 11, 2012 | 04:51 AM
src's Avatar
src
1st Gear
700.00 for gps 135.00 wireing 5 hours. tell me all plug in radio all full up.
