Truck Light Phase 7/'06 FLHTCUSE/Install
Old Nov 12, 2012 | 01:56 PM
t059736's Avatar
t059736
Default Truck Light Phase 7/'06 FLHTCUSE/Install
Good day; Riders.
Could any of you please advise me on what parts I need for install the TL Phase 7 headlite - single connector into my existing High/Low dual light wiring harness?
Your advice and assistance is really appreciated....
Thank you
Old Nov 12, 2012 | 02:42 PM
6burgh's Avatar
6burgh
It's plug and play, nothing else needed on my 07.
Old Nov 12, 2012 | 04:11 PM
t059736's Avatar
t059736
The '06 FLHTCUSE was equipped a high and low light bulb; which means there are 2 independent wiring connectors; one for each light.
What HD part is used to "convert" these two connectors into a single connector for the truck light?
Thanks
Old Nov 25, 2012 | 01:08 AM
hd542's Avatar
hd542
Stage I
Originally Posted by t059736
Good day; Riders.
Thank you
The part number is 71628-04 - WIRE HARNESS, GARAGE DOOR OPEN.
It will plug right into the TL Phase 7 headlight.
That harness will allow you to continue using your garage door opener as well.
That's the harness I used on my 2006 FLHTCUSE.
You can purchase it from surdyke.com for around $28 bucks.
PowerSmoke
Jan 30, 2012 06:48 PM
globeracer59
Nov 13, 2008 10:13 AM
JokersChild
Dec 29, 2007 08:47 PM
HDF Tech
Electrical/Lighting/Alarm
Oct 17, 2005 11:17 PM
