Please post your results w/D&D 2-1. What baffles ect. on set-up. Also need to know who has the best price w/falsie pipe & where to get them. Going w/PCIII & SE high flow filter. Only got 500 more miles before I will install. Need to get them headed this way. BTW, it's a 2007 SE Ultra. Had quiet a few Harley's & this is the best so far. Had it a week today w/500 mi.. Thanks in advance!
Here is a Fatcat dyno when i had andrews tw21 cams, 95 SE FT Pistons,SBC Heads, PC3UBS,Bigsucker,.030HG. Bike is a 05 Ultra.I have different cams in it now but no dyno.
I have lowly 06 103 scremin eagle fat boy only mods. I have D&D Boarzilla, K&N, s.e.r.t, 8mm plug wire's, and It's plenty fast for me, don't plan on getting in motor, It's o.k. Do not know why dyno will not load on this site, like i said it's on softail site, no engine mod's just D&D Boarzzila with performance baffle, s.e.r.t, K&N, 8mm plug wire's. I hit 97.03H.P & 99.87 Tourqe
thank's but was trying to load dyno number's ,well not let me load, but go to softail section and you can see dyno numbers, air fuel ratio flat on 13% ,and 97.03 H.P & 99.87 Tourqe and it was allmost 100 degree's that day also high humidity.
THEY say D&D FAT CAT for harley's that or up to 106 C.I. but if you look they are straight, and the D&D BOARZILLA are for harley's 107 C.I and higher also pipe is up-swept, so I liked that style better and was going to have engine build so I was not worried because I would have big enough motor, also had performance baffle installed so it's loud but to me a good tuned loud, I heard honda 1800cc go by me other day when I was walking my dog's and I'm sure he saw harley tee and hat, so heopened it up for me from stop, boy it was loud! I do not think he even had baffle,but to ME sounded like chit, and then citizen's think it's a harley because they do look alike, then we are the one's making awful loud sound, but any way as luck would have it my fund's had to be spent on other thing's so I can not afford build and far from being wrench, but yes lost a little on low end tourqe but after S.E.R.T., K&N,8mm plug wire's and 103 scremin eagle 06 FAT BOY the tuner did a good job on bike and I'M not going to win any drag race trophy's but run's well enough for me, and if you have110 C.I C.V.O 07, D&D BOARZILLA should be the one for you if (YOU) like it,on high side $800.00.
