Dyno difference in d&d fatcat baffles
Old Nov 17, 2013 | 10:20 AM
Softy 103's Avatar
Softy 103
Default Dyno difference in d&d fatcat baffles
I recently changed cams in my 2012 FLHX. Here is my set up -103", Stock flat top pistons, .030 head gaskets, SE 259e cams, Burley heads, SE Pro tuner, SE Heavy Breather, D&D fat cat. The attached dyno sheet is comparing this build with two different mufflers, a louvered wrapped, and a perforated. You can see the Perforated muffler made more Tq. but less Hp., but also the perforated muffler came on a lot later in the RPM range and also lost out by a little after 5000 RPMs. I didn't ride the bike with both mufflers, and chose to stay with the Louvered muffler for two reasons, First the Louvered muffler is more tolerable, and in my opinion better sounding, and second I think the earlier Tq. with the Louvered muffler is going to be more beneficial. What do you think?
Attached Thumbnails Dyno difference in d&d fatcat baffles-flhx-baseline-with-burly-heads-exhaust.jpg
Old Nov 17, 2013 | 10:56 AM
jus2anoyu's Avatar
jus2anoyu
I've been running a louvered baffle in mine for several years, and recently acquired a perforated baffle muffler. (actually it was a concentric and I removed the 'quiet' part) I think either will work fine, and agree that the slight additional torque at low rpm will be welcome, so, I guess it comes down to sound preference. I'm gonna throw this other baffle on mine soon and see what it sounds like. Louder, I'm sure...
Old Nov 17, 2013 | 12:20 PM
$tonecold's Avatar
$tonecold
I don't know what your riding style is, but for me the louvered would be the best. I like the way the torque comes up quick and then levels out through the whole range. As far as bragging rights everybody worries about HP anyway, so you get the best of both worlds, a bike that pulls great through the range and makes top HP.
Old Nov 17, 2013 | 01:50 PM
mmats69's Avatar
mmats69
I'd take the wrapped baffle. Gained 10 ft lbs down low where you need it and held a better line across the rpm range.
Tim Wayne C
Jan 10, 2021 08:38 PM
oneloudz71
Engine Mechanical Topics
11
Oct 17, 2015 09:36 AM
ColoSpgsMark
Fuel Moto / Jackpot Mufflers
Nov 24, 2012 06:35 PM
FBFletch
Exhaust System Topics
Mar 30, 2012 06:04 AM
uniondog1
Apr 2, 2007 10:03 PM
