Solid Lifter Noise
Old Jan 15, 2015 | 09:50 AM
goatfarmer's Avatar
goatfarmer
I listened to my solids for a long time. Fiddled with settings, different push rods, etc., and just recently put a new cam in and went back to hydraulic units since I don't ride as aggressively as I used to. I thought something was wrong when I started it up, it was so quiet. I have decided that I like it. I just hope these new "Sifton" lifters hold up. They are not made by the same folks anymore. Didn't realise this at the time but so far so good. They have made it for about 2k miles anyway.
Old Jan 18, 2015 | 05:18 AM
AlCherry's Avatar
AlCherry
Sometimes, the problem is, there is no problem. We get to tinkering, adjusting, tightening, and create or conjure up a problem. As in the case of pushrod and solid lifters for shovels, they are somewhat noisy, aluminum or steel. That's just the way they are. 99% of people never ever run their shovels in the rpm range that would cause them to consider light alloy pushrods to speed up the valve train (4500-7000 rpm).
Adjust the cold lash and leave it alone. Go for a ride.
Old Jan 18, 2015 | 07:41 AM
johnjzjz's Avatar
johnjzjz
having drag pipes is a must when solids bother a customer < thats the fix
Old Jan 19, 2015 | 06:31 AM
cajun1957a's Avatar
cajun1957a
The noise that bothers me the most is when its at idle. You generally don't hear it all that much running down the road as much.
randy
Old Jan 20, 2015 | 07:11 PM
johnjzjz's Avatar
johnjzjz
randy
i am not being a jack - wear ear plugs - i do
Old Jan 23, 2015 | 09:06 AM
31choptop's Avatar
31choptop
also the lighter valvetrain components cause less wear on every thing valvetrain related. not just for speed, fastness of valve opening or more power, but it causes less wear and stress on all entire valvetrain. including rollers and friction points. the early sporty motor never had hydraulics from the get go.
Rowdy Fetus
Sep 29, 2016 05:27 AM
IronSav
Jul 29, 2014 08:55 AM
HemiGlide69
Oct 31, 2010 07:27 PM
Anthonyamastr52
EVO
Apr 19, 2009 03:20 PM
SamStone
Jul 21, 2006 01:39 AM
