Rear Cylinder backfire
Old Mar 9, 2015 | 09:43 AM
pjb's Avatar
pjb
Originally Posted by cajun1957a
This is what I did to determine a coil issue. The bike backfires severly out the rear cylinder. I have true duals so I know it that cylinder. I fixed any exhaust leaks I can find and that didn't work. I changed plugs then replace them without success. Finally I took the wired off the top part of the coil and swapped it out with the one on the bottome and vs vrs. I can now here backfiring in the front cylinder pipe although not as loud primarily I assume because the pipe is longer. That has to be the coil. It is specific to the top port on the coil. I have had two completey different exhaust systems on it and it has always backfired out the rear cylinder but this is the first time I swapped the wires on the coil. dual fire Accel coil.
randy
make sure you replace it with the proper type for the dyna s.
Old Mar 9, 2015 | 10:00 AM
cajun1957a's Avatar
cajun1957a
Im sure its a dyna S as I posted a pick of it once on here. Although no markings I was told it was or a knock off of it. What coil should I get for it.
randy
Old Mar 9, 2015 | 10:26 AM
V_twins's Avatar
V_twins
get a dyna 5 Ohm coil... I THINK they are the only ones making them... all others are 3Ohm I think
Old Mar 9, 2015 | 10:55 AM
pjb's Avatar
pjb
I got the DC7-1 high energy coil from dynatek. DC7-1 5 ohm, dual output HD
Old Mar 9, 2015 | 02:33 PM
Racepres's Avatar
Racepres
randy
I can't believe it is the Coil!!!
Put the points plate back in it and run it...
Old Mar 11, 2015 | 08:27 AM
cajun1957a's Avatar
cajun1957a
Well I went all out on this. I bought an ultima programmable electronic ignition system, with coil. single fire set up. The local wrench I trust around here says its all he puts in shovels and it is really kicker friendly. I have never been able to kick start this bike. Something about dead revs. I have a 65 ironhead, kicker only and im aware of how to kick a bike over many different ways. So if this takes care of my backfire and allows me to kick now and then, its worth the effort. I hope. Will keep you guys posted when I put it on Friday.
randy
Old Mar 11, 2015 | 08:33 AM
Racepres's Avatar
Racepres
No Dead revs in a Dyna S.
They are just Electronic Points.
If the Chiwanese Ignition fixes it...Cool.
Why single fire??? What is the Claimed benefit?
Inspect the Advance unit carefully when you take it out...Be interesting to know the condition, and If it may have had any effect on the situation.
Old Mar 11, 2015 | 08:41 AM
cajun1957a's Avatar
cajun1957a
single fire kit was all my supplier had in stock. other than that, I have no preference
randy
Old Mar 12, 2015 | 02:10 PM
cajun1957a's Avatar
cajun1957a
Ok, this is a totally stupid question but im asking. I got the Ultima programmable single fire kit with coil and am ready to install. The bike came with a dyna s knockoff im thinking and ive been told it is more like electronic points than true elec. ignition and that's cool. The instructions say to remove the module from the cone but says nothing about the counter weights that the dyna has. Does everything come out and the rotor cup go directly to the flywheel bolt? I haven't been inside it yet other than just with the cover off. I want to do this as smooth as possible. I can build engines but for some reason, electronics screw me up.
randy
Thanks
randy
Old Mar 12, 2015 | 03:47 PM
Racepres's Avatar
Racepres
randy
Thanks
randy
Yes everything comes out...The EI unit has an Electronic advance curve...that's why it is also static timed to TDC!
That Mechanical advance in there should stay on the shelf with your Points plate or/and Dyna-S
Edit;
Ensure that your Indy has set your E.I. to No Dead Revs...Or you won't be Kick Starting that one.
