Primary belt drive
Old Jan 1, 2022 | 02:48 PM
john lee's Avatar
john lee
modifying the distance between the 2 pulleys wont do nothing but cause problems. get the right belt
Old Jan 1, 2022 | 05:07 PM
Racepres's Avatar
Racepres
Since the adapter plate determines the distance... Not the Primary... 5-speed...remember???
Old Jan 1, 2022 | 10:32 PM
TwiZted Biker's Avatar
TwiZted Biker
Just about every primary belt kit you got back in the 70's & 80's the belts were either a hair too long and ran sloppy or too tight. So you picked up a sacrifice inner at a swap meet and elongated the front holes and ground out the o-ring groove to allow it to move to get the belt tension right. This was back when they made the pulley fit & tooth count fit the available commercial belts. Friggen belts were never consistent in sizes either. You buy 3 of them same tooth count and one would be sloppy and another too tight.
Later Primo kits came with 2 belts, one was always too tight but identical tooth counts. Played that game many times with Indian which came with that kit from the factory the last go round before Polaris bought them.
Ran Karata, Primo and currently BDL with an idler in my hotrod shovel so I don't have to dick with the adjustment games. Also modified things so I can change it on the side of the road in 20 minutes. Been there did that a few occasions.
Old Jan 3, 2022 | 04:20 AM
john lee's Avatar
john lee
what mods did you do for the roadside replacement
Old Jan 3, 2022 | 07:05 AM
hellonewman's Avatar
hellonewman
Old Jan 3, 2022 | 07:36 AM
TwiZted Biker
Ground a couple spots on the inner for clearance around the clutch hub since the back is already cut out to clear the rear belt pulley mod I did years ago. I also took the little tin outer guide on the front pulley, opened the hole for the crank nut to clear that and drilled the guide & tapped the pulley to take 4 1/4" screws to hold the guild in place.
Drop the battery cable at the solenoid so you can wiggle the bendix shaft out of the way, drop the idler and you can thread the new belt in without pulling the clutch pack. Isn't pretty but works well, busted a few over the years.
Old Jan 3, 2022 | 02:21 PM
john lee's Avatar
john lee
thanks why is the battery cable involved.do you put the belt on rear pulley first ? it must be a tight fit getting the belt over the clutch hub starter teeth at the starter shaft
Old Jan 3, 2022 | 03:12 PM
magnum45pete's Avatar
magnum45pete
The starter ring gear is at the rear of the clutch hub so why would ya need to get a belt over it ?.... i think only narrow factory tupe belts had the belt behind it but no one uses those less on a stock bike with full primary covers....
Old Jan 3, 2022 | 03:39 PM
TwiZted Biker
You pull the Bendix out enough without pulling the battery cable it will engage and spin, eat fingers like right now.
This is only if you run the stock primaries and use the electric start.
Old Jan 3, 2022 | 04:09 PM
john lee's Avatar
john lee
thats where my primo belt runs.between the clutch hub starter teeth and the inner primary
