Complete teardrop down or just upper half ???
Old Oct 14, 2015 | 07:10 PM
EricDial's Avatar
EricDial
Default Complete teardown or just upper half ???
I've got a 78 shovel out of frame and planning on tearing down to just see how it is inside before I put on bike. What is the best gaskets and seals to go back with and should I go complete tear down case and all or just upper half. Rockers heads jugs ?
Old Oct 14, 2015 | 09:24 PM
V_twins's Avatar
V_twins
at least the top end and while off, check tollerances and movement of the rods and go from there
Old Oct 15, 2015 | 12:13 PM
EricDial's Avatar
EricDial
Should I just use hd gaskets and seals or should I get aftermarket stuff
Old Oct 15, 2015 | 01:24 PM
YeOldeStonecat's Avatar
YeOldeStonecat
Prefer James or Cometic gaskets.
Old Oct 15, 2015 | 07:03 PM
biginchhustler's Avatar
biginchhustler
I've noticed in several different threads lately that people are having trouble with the James Silicon or Print gaskets.
I used an entire set of Upper End James gaskets including o-rings and push rod tube seals. I also used them for the primary and derby cover and they leaked. The only ones that haven't leaked or weeped are the nosecone and head gaskets.
They leak at different places, at different times and at different amounts. I'm curious as to who has had the same problem. Yes I have checked all the torques I can and they're spot on. I'm thinking it's just a lower quality gasket. I'm trying Cometic this winter.
Is anyone else having these sort of problems with James?
I stopped using them. They have been sold a couple times and are nothing like they used to be.
----- http://www.cycogaskets.com/ ----
Amazing prices and good quality. I'm pretty sure this is the manufacturer that others are rebranding, and charging 10 times as much!!
Old Oct 15, 2015 | 07:04 PM
biginchhustler
that's a reply from shovelhead usa
Old Oct 15, 2015 | 07:43 PM
TwiZted Biker's Avatar
TwiZted Biker
Cometic gaskets don't bother with James anymore and DO NOT use the plain old paper style except on the nosecone & lifter blocks or you'll be building leaks in.
Old Oct 15, 2015 | 08:13 PM
biginchhustler
i use paper on the oil pump copper coat
Old Oct 15, 2015 | 08:22 PM
TwiZted Biker
Yeah better option than the old mylar ones that wouldn't seal till you lapped the cover & mating surfaces flat. I'm a fan of Gasgacinch or Hylomar for oil pumps & tappet blocks.
Old Oct 15, 2015 | 08:46 PM
EricDial's Avatar
EricDial
Cool man. Where can I get these gaskets? From a harley dealer or online. Are the gaskets from a dealer not worth using or are they an option too.
