Power house electronic ignition
Old Dec 2, 2015 | 06:48 PM
EricDial's Avatar
EricDial
Originally Posted by johnjzjz
you have that a bit off - all Harleys from the factory EVO - shovel - are dual fire ignition be it one or even 2 plugs per cylinder - you can buy a single fire ignition what that does is fire one cylinder at a time instead of the waste fire as its called from Harley
in my shop we use the ultima ignition and a dyna coil not the ultima coil as its junk
but dyna's kit is also a good unit -- they as an electronic controlled ignition has switches to change it from dual to single fire for you combo as well as a rev limit and advance curve for performance mods
OK thanks for clearing that up for me. So what would you recommend the ultima electronic ignition and a dynamic coil or would you recommend the Dyna kit and be done with it
Old Dec 2, 2015 | 06:52 PM
EricDial's Avatar
EricDial
Where is your shop at John
Old Dec 2, 2015 | 07:05 PM
johnjzjz's Avatar
johnjzjz
I am in jersey - you can buy what ever is cheapest in a search for both
Old Dec 2, 2015 | 07:10 PM
EricDial's Avatar
EricDial
OK which dyna kit is good. I saw race said that the Dyna s was out dated like mine was so I was just wondering what you thought. Also on the ultima to program it you have to buy the program kit also. Damn I was hoping you were in missouri with your shop lol
Old Dec 2, 2015 | 09:04 PM
johnjzjz's Avatar
johnjzjz
all the ignitions today are plug and play almost or maybe a little wire ends
go to your local indy say hello and get his opinion on a replacement and cost then go amazon and even flea bay - if he is close then get it from him - they all come with good directions
Old Dec 2, 2015 | 09:15 PM
EricDial's Avatar
EricDial
Right on man thanks for the info I'll see what I can find
Old Dec 2, 2015 | 09:56 PM
Racepres's Avatar
Racepres
And...Send me that crappy old thing ya gots...OK
Old Apr 8, 2019 | 11:20 AM
daniroseforever's Avatar
daniroseforever
Stage I
Default power house manual or diagram
i need wiring diagram plesse anyone.i just gotta get it on today!!!
Old Apr 8, 2019 | 02:32 PM
98hotrodfatboy's Avatar
98hotrodfatboy
As John said. Get an Ultima and a good coil and your good to go. You definitely want a unit with a led that helps you set the base static timing.. So much easier..
Racepres, I have a n older Compufire with centrifugal advance. pm me if your interested....
6jhnnyrttn9
Sep 14, 2016 01:22 AM
byronk
EVO
22
May 29, 2015 08:39 PM
EROK97
Jul 20, 2013 11:12 PM
RidemyEVO
EVO
18
Jun 16, 2011 07:32 AM
nathanbedfordforrest
Ironhead
Aug 5, 2007 02:38 PM
