how far should I go
Old Feb 22, 2016 | 06:55 PM
RSDUDA's Avatar
RSDUDA
Default how far should I go
I am about ready to pull down my shovel to install 2 new cylinders and pistons to try and take care of a smoking problem that has been troubling this bike for a few years now , mu concern is the lower end has never been touched it is not noisy but it is 40 years old there maybe 30 to 40k miles on it not sure if I should spend the money on it or not
thanks
Ron
Old Feb 22, 2016 | 11:51 PM
Squidbilly*'s Avatar
Squidbilly*
Go as far as ya want or need to Ron
Just depends on how much your attatched to the machine,
Once ya get her apart will tell ya how loose the rods&flywheels are,
You'll either fix it yourself,
Pay a compentent shop for the work,
Or it'll end up a basket case,
If the bottom end is not making noise as you say,
You may be golden with the top rebuild
Old Feb 23, 2016 | 05:11 AM
RSDUDA's Avatar
RSDUDA
thank you I will look harder at it when it is apart
Old Feb 23, 2016 | 06:05 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Bring the crank pin around to approx. the 5 o'clock position, and feel for any up/down movement on the male rod.
Excessive side/side per service manual specs needs to be checked as well.
We've witnessed Shovels many, many, years ago in need of a top end at that mileage, with the crank on the high side of service specs(alerted the customers) only to have deep noises in the engine after about 1500-2000 miles, which the now sealed-off top end, finished off the crank.
Not trying to scare or secure work, only sharing info, but happy to lend a hand if need be.
Scott
OHIOGoatMan
EVO
Aug 15, 2017 09:13 PM
dzuniga770
General Topics/Tech Tips
Aug 11, 2016 10:39 PM
JC in Colorado
Apr 6, 2013 04:51 PM
olsenam0822
EVO
May 17, 2011 07:41 AM
ohioflhs
Exhaust System Topics
May 9, 2010 07:39 AM
