Strange Shovelhead
Old Apr 10, 2016 | 11:33 PM
vanmor's Avatar
vanmor
Default Strange Shovelhead
Hey Everyone. Went out Friday night and bought a Craigslist find.
I noticed in the picture that things didn't seem normal. Notice there is a lot of space between the frame and rear head. The fron legs of the frame are a bit longer too. When I got there, I found out the engine had delkron cases. The seller said it was stroked to 96" cu. in.
The heads have removable plugs on the carb side. The heads also have fittings that let it drain oil through hoses to the cases.
There is a belt drive in the primary cases.
The frame is aftermarket. For now, I'm going to guess it's a Santee. The frame has been repaired before and is now broken at the rear bottom behind the kicker.
This ain't my first Shovel but it sure is different. The only thing H-D is the suspension, gas tank, fenders, and transmission.
I'm currently trying to ID the flywheels.
bynbay
Oct 15, 2017 06:35 PM
vanmor
Shovelhead
Apr 15, 2016 11:24 PM
alfajuj
Custom Models
Nov 27, 2012 10:50 PM
CSA
Custom Models
May 25, 2008 04:31 PM
