I'm doing some maintenance to my clutch and among other things I'm going to replace the inner primary bearing. Do I need to pack this bearing with grease? I'm wondering if I should put some Lucas #2 red and tacky on it or maybe just leave it alone like the starter jackshaft needle bearing.
if its dry it should have a shielded bearing for a belt drive and YES we re pack them every season but i use the green grease from 2 guys garage its the best i have ever seen and used it gets on everything when you use it
