Timing
Old Jun 5, 2017 | 08:36 AM
Ston's Avatar
Ston
Default Timing
I have 82 shovel with dyna electronic ignition with B2 Andrews cam.I have never used a timing light and need help trying this.
Old Jun 5, 2017 | 07:28 PM
johnjzjz's Avatar
johnjzjz
in my shop we do lots of unit engines for other shops and not having the chassis -we set the timing static using a battery - coil , plugs and plug wires,
turn the engine over with the rear intake pushrod cover open so you can see the intake pushrod - rotate the engine till the line or dots < your engine - are coming to the center of the timing hole and at the same time the rear cylinder intake pushrod is moving up ( opening the intake valve ) eyes in the hole finger on the R intake pushrod
at the center of the hole will be the front cylinder advance spot - then rotate the center trigger wheel to the advance spot all the way, and just as it stops you should see the plugs spark - tighten the - point / dyna trigger - plate screws and your done no need to get soaked with oil
if you have a total electronic controlled module the turn clockwise till the light goes out your done
Old Jun 6, 2017 | 08:01 AM
Ston's Avatar
Ston
Confused will the plate move when the trigger is advanced
Old Jun 6, 2017 | 06:17 PM
johnjzjz's Avatar
johnjzjz
what your doing is holding it in the total advances location - and rotating the plate to it so the thing trips and fires the plugs just at that exact spot - not before and not after
don't over think it - its a simple adjustment at the spot the engine is at total advance and you lock it down - your done its that simple
Old Jun 7, 2017 | 06:23 AM
Ston's Avatar
Ston
Thanks for clearing that up.Should be easy now
Old Jun 7, 2017 | 06:32 AM
Ston's Avatar
Ston
Just want to make sure,turn turn trigger counter clockwise to full advance.
skinny1958
Shovelhead
11
May 29, 2018 09:04 AM
RidemyEVO
EVO
Apr 28, 2015 07:03 AM
cajun1957a
Shovelhead
11
Oct 31, 2014 05:11 PM
AmericanNightmare73
Ironhead
Feb 27, 2012 12:29 AM
craezlarry
Ironhead
Jul 21, 2009 08:40 PM
