‘77 backfiring
Old Aug 15, 2018 | 05:15 PM
doc308's Avatar
doc308
Default ‘77 backfiring
I’m still sorting out my newly purchased ‘77 fxe . Today, I took it out for the first real ride. The first hour was fine. Then, the engine began to backfire whenever I turned the throttle quickly. When nursing the bike along with a steady throttle at low rpms, it ran OK but, under load the backfiring got worse and worse. There was no backfiring when letting off of the throttle , only when accelerating.
I removed the carb , cleaned it out ( it looked pretty clean inside) and reinstalled it. This did nothing to improve the problem. I am now questioning if it could be the coil . Is there a way of testing out the coil? Also, any other ideas about what could be causing this.
Old Aug 15, 2018 | 08:03 PM
14GuineaPig's Avatar
14GuineaPig
How are the plugs? If you're running points, check that they haven't closed.
Old Aug 16, 2018 | 06:46 PM
Racepres's Avatar
Racepres
If yer runnin points ... replace the condenser with a Known good one [note I did Not say New] Seen it many a time.. it will get to where it won't pick up RPM at all if it is the condenser..
Old Aug 16, 2018 | 07:57 PM
doc308's Avatar
doc308
Yes, this has a points ignition. I will check them closely and install another condenser tomorrow . The plugs were new Autolites. When I checked them after getting home, they were wet with fuel--obviously not firing correctly.
Thanks for the tips . I'll give you updates as I continue to try to fix this
Old Aug 17, 2018 | 07:30 AM
Racepres's Avatar
Racepres
While yer in there... ensure you have a Quality [no, I do not know where to get a Quality one anymore] Mechanical Advance mechanism.. at minimum ensure yours functions Properly... [perfectly is preferred]
Old Aug 17, 2018 | 11:52 AM
doc308's Avatar
doc308
Bingo—- it turned out to be the condenser. The one that went bad was purchased brand new about 3 weeks ago and has about 75 miles on it. I plugged in an old one that I’ve had kicking around and all symptoms disappeared. To reality test it, I reinstalled the bad one again and, sure enough, all symptoms returned. Thanks so much for the advice. I didn’t consider the condenser because it was new.
Old Aug 17, 2018 | 12:50 PM
Racepres's Avatar
Racepres
New don't seem to mean squat no more... So i say "known good"... Now... test whatever others you have around and label them!!!!!
Yer already right there!!
Randall
Mar 2, 2017 03:24 PM
ryanek9freak
Nov 1, 2010 03:03 PM
markymark02
Shovelhead
Mar 24, 2010 06:19 AM
TRAVIS174
Feb 5, 2010 10:54 AM
graultytc88
Exhaust System Topics
Apr 28, 2009 07:23 AM
