Ignition Problems
Old Sep 24, 2018 | 08:18 PM
Joe12RK's Avatar
Joe12RK
Thanks, but it's a B, so no acc pump. Can't tell from the video but it sputters at steady speeds too.
Old Sep 25, 2018 | 01:55 PM
Racepres's Avatar
Racepres
Different Condenser first... then??? i'll give it some thought..
should run out well on points... Tho I change coils, to 5 ohm with points, even if temporary
Old Sep 25, 2018 | 05:48 PM
Joe12RK's Avatar
Joe12RK
I sprayed starting fluid on the intake and nothing changed, so no leaks there... Tomorrow when it cools off I'll verify that valve adjustment hasn't gone bad. I can hear them but didn't notice if that is new or always been like that. I don't have a 5-ohm coil to use, but I did put a 2-ohm ballast resistor in line with the positive side, like on a car.
Old Sep 26, 2018 | 06:11 PM
Joe12RK's Avatar
Joe12RK
I re-adjusted the valves - front intake and rear exhaust were tight. It seemed to help, but still not perfect. I started it on the enrichener and it ran great, but I closed that and it went back to missing. I rode around the neighborhood, and on the enrichener it ran good at low speeds, but felt flat at higher RPMs. With the enrichener off, it missed at low speeds but ran good at higher RPMs. On the enrichener the exhaust has a lot of black smoke when I crack it off idle. I looked up my jets - 31 intermediate and 72 main, which should be plenty...
Old Sep 26, 2018 | 08:53 PM
johnjzjz's Avatar
johnjzjz
intake is at issue - don't care what you checked
Old Sep 27, 2018 | 06:41 AM
78lowrdr's Avatar
78lowrdr
I agree. With that jetting, I think it would be a fat mixture. I see folks have made a manifold test block where you can put 10 psi to it,
and spray soap water on the sealing area to check for leaks.
That said, I usually do not try to chase a mixture issue until I know the ignition is as good as it can be.
Old Sep 27, 2018 | 07:40 AM
Racepres's Avatar
Racepres
Can't anyway... That's why I keep a Known/Tested Good Points ignition system on the shelf. ..
Old Sep 27, 2018 | 12:00 PM
98hotrodfatboy's Avatar
98hotrodfatboy
A .031" in the intermediate seems big for an E.... What's in the build?
Old Sep 27, 2018 | 02:09 PM
78lowrdr's Avatar
78lowrdr
It's an 80" with a B carb.
Old Sep 27, 2018 | 03:07 PM
98hotrodfatboy
A .031 is big I would try a .0295" I went to a .028" in my E on a modified 74"er and love how crisp the throttle response is..
