Ignition Problems
Old Sep 27, 2018 | 04:49 PM
Joe12RK's Avatar
Joe12RK
Thanks guys! I tightened the intake clamps a few turns, and opened the idle screw a turn and it is a lot better. I think the electrical friction tape over the o-ring helped. I will have to re-learn how to do it over. But now I'm going to Jewett City for the annual bike night.
I found a .295 intermediate jet, but not sure if it's from an E or a B. Are they the same?
Old Sep 27, 2018 | 05:36 PM
johnjzjz's Avatar
johnjzjz
same all the S&S jets fit any carb
Old Sep 27, 2018 | 08:55 PM
TwiZted Biker's Avatar
TwiZted Biker
A .031 is big I would try a .0295" I went to a .028" in my E on a modified 74"er and love how crisp the throttle response is..
B's don't like the .0295 they tune out better with the .031, was an E carb you'd be right.
Old Sep 28, 2018 | 06:27 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I guess with the 1 7/8" diameter it would need a little more fuel... Is the B a tapered venturi like the E or G?
Old Sep 28, 2018 | 07:27 AM
Racepres's Avatar
Racepres
I guess I thought the '79 utilized the Rubberband Manifolds???
If O-ring, I use 3M electrical tape [one wrap, not friction] Haven't had a leak in Years, but a mess when replaced...
Old Sep 28, 2018 | 03:37 PM
TwiZted Biker
Has more to do with no accel pump than venturing size , fatter jet helps overcome the lean spot the accelerator pump usually handles. Ran B's for years, still have several in box stashed.
Old Oct 1, 2018 | 07:35 PM
Joe12RK's Avatar
Joe12RK
I'm glad it was running badly with points because it made me check the valves and intake and fix them. Now with a new ignition module it runs great! Even better than before
Thanks for all of your help!
1988lowrider
EVO
11
Jun 1, 2018 03:31 PM
Rustygold
Jul 15, 2016 11:22 PM
bchrist320
Jun 10, 2013 09:42 PM
daholken
Mar 28, 2009 09:46 PM
zenwarrior
May 19, 2007 11:21 AM
