Gas cap venting
Old Oct 28, 2018 | 07:37 PM
doc308's Avatar
doc308
Default Gas cap venting
I have a '77 FXE equipped with the smaller, one-piece gas tank. Should the cap on this tank be vented? I notice quite a vacuum whoosh whenever I remove the cap after running.
Old Oct 28, 2018 | 07:57 PM
Racepres's Avatar
Racepres
Certainly needs to be vented.
Actually it wouldn't run long, if Not vented... I suspect that when you remove the cap [especially on a Warm sunny day] the "sound" you are hearing is actually a Pressure release..
Prepare to get gas in yer mouth to test it tho... Many replacement automotive caps allow air in ... suck on the inside of the cap and air should come in, Blow on the inside of the cap, and no air goes out..
That is my suspicion anyway...
Old Oct 28, 2018 | 08:58 PM
johnjzjz's Avatar
johnjzjz
its actually better to get a new cap then suck on stale gas - just saying
Old Oct 28, 2018 | 11:08 PM
Squidbilly*'s Avatar
Squidbilly*
Common physics tell ya what must be replaced when extracting another material,
Thus no replacement creates a vacuum,
So yes drill a hole in the gas cap,
Old Oct 29, 2018 | 08:50 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Look for your tank vent line it probably has a blockage in it you need to blow it out or change it, you can easily collapse or suck in your tank.
Old Oct 29, 2018 | 09:17 AM
Racepres's Avatar
Racepres
On yer Shovelhead??? Not with Bayonet caps!!!! Maybe with screw ins....
Old Oct 30, 2018 | 07:28 PM
doc308's Avatar
doc308
Thanks, comrades.
Cobytur
Jul 31, 2013 09:48 AM
Gunny68
General Topics/Tech Tips
Jan 11, 2013 08:16 PM
WA7MM
Dec 26, 2012 10:36 PM
grancuda
Apr 16, 2012 10:24 PM
1unclejojo
Shovelhead
Aug 12, 2008 06:22 PM
