Primary cover won’t come off
Old Dec 15, 2018 | 08:23 PM
Bill wallace's Avatar
Bill wallace
Panz...aftermarket. Can’t use gasket remover because the inner-primary is powder coated. I used permatex Right Stuff.
Old Dec 15, 2018 | 09:37 PM
Racepres's Avatar
Racepres
Originally Posted by hellonewman
And if you followed every suggestion the WSM suggested you would have a leaking piece of crap for a bike.
I don't... but, experience helps some also...
Sorry your Experience was so negative..
Dammit!! Now that a Problem... you are back to a Box cutter etc ... as suggested.. carefully, and yes up high on the case, just so as to get above the oil level...
As I have said in the Past... the best use I have found for Powder Coat has been as a coating on my Cast Boolits!!!!
Yea... I'm a COB.....
Old Dec 16, 2018 | 05:25 PM
Bill wallace
Default Got her off!
Hey guys, thanks for all the great advice. I wound up using about a half dozen utility knife blades. I took a hard plastic mallet and very carefully tapped them in as straight as possible. Once I broke the seal around the upper half of the primary cover, I took a wooden shim and was able to get it between the inner primary and the outer primary and started tapping. This popped it off. The inner primary and outer primary came out Unscratched. And so the winter tear down begins. Thanks guys!
and you know what? That primary was on there for over a year and didn’t leak a drop. I used Permatex Right Stuff and now that I know how to get it apart, might use Right Stuff again. But I did order gaskets for the cam-cover��!
Old Dec 16, 2018 | 09:39 PM
Hurricane 68's Avatar
Hurricane 68
Default Try heat next time
have used that kind use a decal heat gun next time softens up comes apart and no damage to paint chrome or whatever
JensBobber
Apr 8, 2019 07:11 AM
dproto09
Jan 19, 2017 10:07 AM
kevdog
Nov 20, 2010 12:32 AM
trip20
Aug 6, 2010 03:14 PM
matschang
Jul 29, 2006 01:13 AM
