Primary cover fitment?
Old Nov 9, 2010 | 06:45 PM
kevdog's Avatar
kevdog
Default Primary cover fitment?
I have a 2008 FLHTC that went down on the left side, scratched and dented the primary cover so there is a slight leak at the bottom of the derby cover. Will a primary cover from a 2007 Ultra Classic work as a replacement? How many gaskets am I looking at to replace in doing this? Any tips are appreciated.
Old Nov 9, 2010 | 06:50 PM
dawg's Avatar
dawg
07-11 TC96 touring primary will fit.
bubbabear's Avatar
bubbabear
I'm pretty sure it will work, you will need the outer primary gasket and a derby cover gasket.
Old Nov 9, 2010 | 06:54 PM
dawg's Avatar
dawg
A tip for ya is to put in the SE comp and check things out with your tensioner while you're in there!
Old Nov 9, 2010 | 08:00 PM
kevdog's Avatar
kevdog
What is a SE comp?
Old Nov 9, 2010 | 08:16 PM
dawg's Avatar
dawg
Screamin' Eagle Compensator
Old Nov 9, 2010 | 08:26 PM
xdanman's Avatar
xdanman
Default re
Dawg, Is the 2010 tensioner a better design? I am going to replace the comp, do I need to upgrade anything else?
Old Nov 9, 2010 | 09:02 PM
dawg's Avatar
dawg
The 2010's are using the updated -06B tensioner.
Old Nov 19, 2010 | 11:43 PM
kevdog's Avatar
kevdog
Does anyone know how many ounces of tranny fluid I need to use when I change the primary cover and the gaskets? Also is there a decent aftermarket brand that I can pickup at the local Autozone?
Old Nov 20, 2010 | 12:32 AM
Clint55's Avatar
Clint55
38 oz. Don't go any further unitil you get a service manual. JMHO.
baka1969
Oct 5, 2023 05:31 AM
JensBobber
Apr 8, 2019 07:11 AM
kennyking0810
Jul 14, 2017 07:18 PM
DannyZ71
Apr 21, 2012 01:48 PM
trip20
Aug 6, 2010 03:14 PM
