What else besides stroker flywheels?
Old Dec 25, 2018 | 07:22 PM
Bill wallace's Avatar
Bill wallace
Default What else besides stroker flywheels?
So...I’m seeing Truett & Osborn 4-1/2 inch stroker flywheels on eBay for $500. I know how to split cases and true flywheels and balancing seems like something I could figure out. Is it possible to just add stroker flywheels and probably new bearings and reuse stock everything else? What am I missing? This seems Seems too easy.
Old Dec 25, 2018 | 07:58 PM
johnjzjz's Avatar
johnjzjz
you need to clearance the block inside at the top and out side edges of the jugs and one spot in the block its self
having said that sometimes enough room is in the block your only talking 1/4 inch more up and down
they do take special pistons that have the wrist pins re located for the different stroke
the oil ring ends up being flooded if you do not re locate that hole in the jug and block that drains the top end oil - you can drill it straight down into the flywheel area - but that sometimes causes more drag then changing the block holes and jug - comes down to oil pump volume to the heads - the strokers like a 2 hole crank pin not the stock one hole and I am not a fan of the three hole as the three holes are in the center of the rollers travel
you will need S&S directions to attempt this - have no idea what T&O gives for this as I have never seen any
Old Dec 25, 2018 | 08:06 PM
Kingglide549's Avatar
Kingglide549
I try never to be a knocker of people that are truly trying hard.
But for a one time shot at wheels, I don't think so.
It is not worth it.
The S&S balancing plug weights will probably cost more than hiring a person with experience.
The degree wheel is needed to open up the breather port.
I am pretty sure you will need longer rods and different pistons.
I am not saying you cant do it...
but if money is the concern I am thinking it will be cheaper to hire the guy. (whoever you choose.)
JMO
Loaf
General Topics/Tech Tips
Feb 21, 2020 05:11 AM
Jim Hunchuk
Knuckle Head
Sep 27, 2018 02:54 AM
Nevsat13
Shovelhead
22
Aug 15, 2014 08:52 AM
bsteve
Shovelhead
Sep 30, 2013 04:51 PM
brokeboystreetglide
Exhaust System Topics
13
Jan 6, 2010 05:57 AM
