72 shovel cam and breather end-play
Old Dec 30, 2018 | 03:27 PM
Bill wallace's Avatar
Bill wallace
Default 72 shovel cam and breather end-play
Hey guys, I’m putting an Andrews cam in my 72 shovel and I have a couple questions. The FM says to check the breather end-play without the gasket. The FM says it should be .001 minimum. This has me kind of baffled Because without the gasket, my machinists straight edge actually rocks on the breather spacer And you cannot touch both sides of the case with the straight edge. When I install the gasket, I have about .008 clearance. The gasket is supposed to crush .006 with proper torque Which would leave me .002 end play. So how do I do this?
Old Dec 30, 2018 | 04:19 PM
1981 suprglide's Avatar
1981 suprglide
stay away from this one very disappointing for me
Old Dec 30, 2018 | 04:57 PM
Racepres's Avatar
Racepres
alway check thru the tapet block [removed] and shoot for 10 thou. with gasket in place and cover torqued....
Ai't never had issues... and BTW for me loose is better than too close...
On the breather... i ain't very fussy ... easy enough to put a spot of clay on the spacer and try for "very loose"
Old Dec 30, 2018 | 06:09 PM
johnjzjz's Avatar
johnjzjz
very true what race posted - we just get the breather to rock back and forth with a pick not zero - and the cam is easier as we have a dial tool to check in and out
the gasket paper today is not the same as when the books were written about paper crush you could rely on
08hogheaven
Welcome Area Only
27
May 31, 2020 05:48 PM
Mick.vs.theworld
22
Jan 24, 2019 07:04 PM
TravelingTall
Harley Davidson Videos
23
Jul 13, 2018 12:18 AM
