spark plug
Old Jan 15, 2019 | 04:02 PM
john lee's Avatar
john lee
Default spark plug
a mates fx shovel was misfiring on the rear cylinder.pulled both plugs and looked good even had a second opinion.so just out of curiosity replaced the rear plug and all is good. has anyone come across that before thanks
Old Jan 15, 2019 | 04:34 PM
old mago's Avatar
old mago
plenty of times...treat your plugs with kid gloves...dont drop em
Old Jan 15, 2019 | 04:38 PM
1981 suprglide's Avatar
1981 suprglide
only had this with champion spark plugs
especially the rear cylinder the first one to go
because it run hotter
Old Jan 15, 2019 | 04:45 PM
Squidbilly*'s Avatar
Squidbilly*
Pluggs are operators choice just as,
Oil,
Filters(both air&oil)
Tires,
What kind of air to put in them,
Points or electronic ignition,
Find the combo that makes ya happy,
Old Jan 15, 2019 | 05:01 PM
john lee's Avatar
john lee
was champion plugs
Old Jan 15, 2019 | 05:09 PM
Racepres's Avatar
Racepres
Originally Posted by john lee
was champion plugs
Never had a problem with Champions... In fact About the only Plug that will recover from wet fouling is a Champion... NGK??? Forget it.
Found many times that the Squirter is pointed at one cylinder or another ... an a Throttle Jockey can foul the cylinder being Squirted... Just sayin..
BTW As a matter of fact..., While riding.. The rear runs Cooler... Check for yerself..
Know Why???
Flame on!!!!
Old Jan 15, 2019 | 05:44 PM
biginchhustler's Avatar
biginchhustler
your gonna be told by the pros on here that the "front" cylinder is the one that runs hotter- and I agree---
Old Jan 15, 2019 | 05:47 PM
hscic's Avatar
hscic
I can vouch for that....after I replaced my fairly new AC Delco with new NGK and setting idle, I couldn't start the bike. Cleaned the NGK and still could not start. Removed the NGK and replaced with new AC Delco and started right up. NGK no more.
Old Jan 15, 2019 | 06:04 PM
johnjzjz's Avatar
johnjzjz
well the front cylinder is hotter TO ME for a couple of reasons
1 its out of the way in the oil spray from the flywheels unlike the rear
2 the pull of the machine as its going forward the intake mixture is heavy latent with fuel this causes it to lean out - But if you tilt the carb to the rear a few degrees that goes away just like the XL factory 2 carb race bikes the carbs angled to the rear - on a dyno we looked at that and the egt did fall off ( went rich ) with the angle - but then the rear didn't like it
Old Jan 16, 2019 | 11:23 PM
1981 suprglide
wow I don't get it the front cylinder catches the fresh air first
how can it be hotter and why Harley designed a device for
putting air on the rear cylinder it fits on the dressers I'm sure
somebody here has one
