the wear on the rubbing block if you never re set the timing - but re setting the starting location at the front of the point brake gives you the correct start of initial timing NO - the difference is in the slope of the points as it relates to timing only sees the first part when it brakes to fire the coil - the rest is the dwell - the amount of time they are open
I am not getting how the timing is retarded as a result of rubbing block wear
the only thing I can get from this is the cam shaft and the points are out of phase with one another and its very small not even 1 degree
compu-fire 20100 ignition dual fire is hard to beat and
easy to install use the same mechanical advance and
will run for years and dude that is one sweet shovel
I had someone tell me a while back that points are usually easier to start on a kick only. I have no experience with points but I'm not afraid to dive into it with a little guidance. The kits are cheap and if that's all I need then I'll go for it. I'm not running breakers. No signals. Just running lights and breaks. Ignition is an on off toggle.
I will try this one more time ...time...argh argh
If the dwell is set, over time the gap gets narrower, this is esp more noticeable in a car (more miles usually)
As the wear block is moved by the cam and lifts the points it slowly becomes worn -less and less gap-
Which means the points open latter and the timing becomes more retarded.
Yes you can compensate for it by resetting the dwell (gap)
If I remember correctly I went coast to coast on the sporty without touching the points ..a long long time ago
.Points are not as high maintenance as some may think them to be.
the points rubbing block fixed square is way softer then the metal cog for lack of a better word and even with out point grease back in the day 8 cylinder distributors had 8 segments not two and 100,000 miles later the dwell was spot on
if wear is a real issue then the dwell would become shorter NO 6ou would not be able to achieve 30 degrees - as the open and closing time would be less and I don't see that with 8 cylinder cars even with way over 100,000 miles and detectable dwell narrowing
