Points conversion
Old Feb 18, 2019 | 07:42 PM
timber0472's Avatar
timber0472
Default Points conversion
Hey guys I've got a 1980 shovel with a Daytona ignition in her. The bike is kick only and I really want to go back to points. I know I've seen some accel kits out there for pretty cheap but is there anything else needed? Looks like the kits usually comes with the condenser, points, backplate, and a spool of wire with crimp connectors. Any thoughts? How hard was it? I heard that points are a snap to start vs the electronic kickers. She used to start great but as time goes on it seems like something isn't quite right.
Thanks in advance!
1980 harley fxe with 79 fl ratchet jockey 4spd.
Old Feb 18, 2019 | 08:47 PM
johnjzjz's Avatar
johnjzjz
the centrifugal advance unit if it has one is going bad - the only one that works is the one with the bearings for the weights - switch it and see what happens - you will be needing a new one with points anyway
Old Feb 18, 2019 | 09:01 PM
Kingglide549's Avatar
Kingglide549
Points/ condenser, coil, is about as simple as it gets.
Chevy 6 cylinder points fit.
Most any condenser you fit in there will work
Old Feb 19, 2019 | 08:12 AM
timber0472's Avatar
timber0472
My current coil won't work? Forgive me for asking but why? And all the kits I've seen do not come with a coil. Just curious as to do I need a special coil.
Thanks!
Old Feb 19, 2019 | 08:45 AM
Kingglide549
Your electronic coil prolly will not work if it is for electronics.
Points coils and electronic ones are different ohms
points are usually 5 OHM and everything else 3
You could try it as it is a breaker system and may work for a long time..but have a spare in your back pocket.
More info below
https://www.jalopyjournal.com/forum/...stions.439044/
Old Feb 19, 2019 | 02:36 PM
john lee's Avatar
john lee
why is points better
Old Feb 19, 2019 | 03:25 PM
johnjzjz's Avatar
johnjzjz
its not better they no longer have tungsten coating on the tips like we had when cars were still using points
and 6 volt is 1.5 ohms in a coil just because some of us have collections of 6 volt machines
the dyna trigger uses the came coil as a point ignition at 5 ohms
Old Feb 19, 2019 | 03:29 PM
Kingglide549
It depends on whom you ask-
I know they are better because I can fix a problem anywhere.
Us old guys grew up with points and condensers in everything.
In cars, they were replaced about every 6 to 10K miles .
They could use a mid-time point timing adjustment, as the rubbing block on the points wears away.
This cause retarded timing.
With electronic timing, there is nothing to do after the initial adjustment.
When it breaks dwn on a cold dark night there is no way to fix it
That is the total difference between electronics and caveman.
Do I have points?
yes and no
I run Daytona because of the timing needs and double plugs.
On long trips, I carry the old school breaker plate complete with a coil to get out of a jam.
If I did not have double plugs and timing needs I would run points .
Old Feb 19, 2019 | 04:25 PM
1981 suprglide's Avatar
1981 suprglide
compu-fire 20100 ignition dual fire is hard to beat and
easy to install use the same mechanical advance and
will run for years and dude that is one sweet shovel
Old Feb 19, 2019 | 05:25 PM
johnjzjz's Avatar
johnjzjz
Do I have points?
yes and no
I don't get this you wrote above - what does a slight amount of retard in timing needs have to do with running or not running points - makes no sense and you split the ohms and run twin coils for 4 pugs - in the 80s we 100s that way
