Just had the tranny in my '77 rebuilt and the neutral light does not come on consistently. If I lightly press down on the shift lever while in neutral it comes on and will stay on as long as i hold it down. However, when allowing the lever to pop back up to the neutral position the light goes off. So--are these switches prone to failure? would changing the switches gasket to thinner or thicker one make any difference? I can live without it but just curious if there is a fix short of replacing the switch or pulling the transmission out again( which will not be done!) . This doesn't seem to be a bulb issue as it will go on and stay on as long as i hold the lever down a bit.
Take it too who did rebuild...maybe not timed rite...just a guess. But i think i screwed one up a lng time ago.. the detent was off..... pull the switch out when its in neutral see if you can see the notch sticking up in the hole...get a good light
the switches are at best ok - but once you wash out the trans and re install the thread can stretch causing the end ball to loose its ground - its not that big a deal to replace it they are available - picture up yours and go looking so you get the same one - 6 different ones but not all fit the same location - helps if your trans is correct for the year
one tooth off ether way and it does not up shift or down shift - then the finger catches don't line up - its right or its not
how can it not be in timing and still work
I did screw one up....it might have been a sloppy one as i could get first gear....and it got 4 th too. But i f ed up were the tit lines up to hole .... i could very well have screwed something else up,with it... easy to check...neutral and the tit has to show when you pull switch. Can check switch too that way. Figure out debth of switch. Than check tit......
I have one here that does Not have the Nub aligned to the switch when in neutral position... Why??? IDK...always suspected mismatched Parts ie one up 3 down vs 1 down 3 up... But????
I pulled the one i screwed up apart ...long long time ago...no parts and fixed it. I did something asbackwards.....too long ago to remember
