I just installed a new Dyna S ignition and single fire coil on my '79 FXE 80" and am having problems following the static timing instructions. I have searched this forum and tried a few things but no luck. My main issue seems to be that my test light stays on throughout the whole range of adjustment of the ignition plate, it doesn't make any difference if I turn the advance against the weights either. I have the advance line visible in the timing window (should I have the TDC dot visible? I tried that too). Have I done something wrong with the wiring? I ran the blue wire to the top of the coil, where it connects to a double plug with the other wire that runs up to the tach. The white wire goes to the bottom of the coil and joins another white wire that runs to switched power. Is that all correct?
Thanks for any help anyone can offer.
Wiring is correct... if in fact you have an ignition that says Dyna right on it... if a Chiwanese reproduction... they are sometimes bass ackwards..
Follow the Instructions for points set-up and all is well....
It snaps back. Everything seems right except for the fact that the test light stays on throughout the whole range of timing adjustment. When I use a voltmeter instead of a light, I get a full 12 volts throughout the whole adjustment range, it doesn't fade in or out as it approaches the perfect spot - is it supposed to? I have gas flowing out the bottom of the carburetor when I turn on the fuel so I need to pull it and deal with an apparent float issue before I can try to fire it up and see if it starts. I'm just worried about the static timing because it doesn't seem to be working the way all of the posts and directions say that it should.
I ordered the unit myself and installed it according to the printed instructions that came with it. The only issue was that the directions didn't tell me what to do with the original white wire that ran to the bottom of the old coil. I left it connected to that bottom post of the new Dyna coil because it is the only thing powering the coil.
Those are the printed directions that came with the Dyna package. Pretty over-simplified. They say to hook the white wire to the bottom of the coil, they don't say what to do with the original white wire that powered the old coil. Since the new white wire that comes from the new ignition module has no power source there is no power to the coil if you do it as simply as these instructions say. So I connected the old white switched 12v white wire to the same bottom post as the the new white wire from the ignition module (the old points never had 2 wires, just the blue one that went to the top post). It's possible that this is not correct but I have no way of knowing, that's why I'm asking here. I assume that I have done something wrong to be getting power through the whole adjustment range instead of one specific spot. I'm not finding a tech support page or phone number at Dynatech, just FAQ's.
^^ Actually... the Points does need to have that white [power] wire and the blue is triggers... sometimes accompanied by pink wire [Tach]
No the directions are dead simple... and nowhere does it say "disconnect" the existing white wire...
Now... If perchance that Dyna module was ever... even for a Split second.. been attached Backwards... it is now Junk... only the Chiwanese copy can be hooked Backwards and Survive... won't work... but they live thru it to be attached bassackwards from the Real Dyna...and Function...
