Stock Front Fender
Old Sep 18, 2019 | 08:47 AM
jfcroni44's Avatar
jfcroni44
Default Stock Front Fender
I need a stock front fender for my 1973 Shovel FLH. Does anyone know what year range will work?
Old Sep 18, 2019 | 10:01 AM
Racepres's Avatar
Racepres
I never found any difference ...since HydraGlide's... thru 4-speed Shovels anyway!!! Never tried a 5 speed front fender... but is sure looked the same...
Differences are badging, trim etc... certainly...
Old Sep 18, 2019 | 11:35 AM
Architect's Avatar
Architect
1976 is bolted to the supports, not riveted. That is all I got, I agree they mostly all look the same except for mounting holes for trim, brake lines etc.
This is a nice one that is OEM and not aftermarket:
https://www.ebay.com/itm/ORIG-PAINT-...4AAOSw6kBdftyo
Old Sep 18, 2019 | 12:32 PM
Racepres's Avatar
Racepres
I would certainly Hope so for that kinda Jack!!!!
But, I suspect trim like the tip, spears, and that light, add up if sourced separately..
I am Not very good at Identifying O.E. vs A.M. on FL Front Fenders... Even between Riveted and Bolted...and reinforced, and not reinforced... I get confused!!!
Old Sep 19, 2019 | 05:56 AM
Architect's Avatar
Architect
IDK, that fender seems pretty reasonable considering everything included. As you noted, the smalls would eat away at your wallet if you needed all of that. Now if you could find they guy with the rest of that tin set and needed that specific color, now you have gold.
I would try to find Milwaukee steel.
Old Sep 19, 2019 | 06:21 AM
hellonewman's Avatar
hellonewman
The mount tabs evolved throughout the range starting with a simple punched out tab to a stamped tab with a contour to it ending in siamesed tabs that have a bridge joining them behind the slider. Its the first thing I look at when I see a 60's FL for sale and most have the wrong front fender where they put a RK fender on. They fit but that detail is wrong if it matters to anyone.
Cagmo
Apr 24, 2020 09:56 AM
89FLHTC
EVO
11
Apr 6, 2016 10:31 AM
dcdr
Mar 10, 2013 02:28 PM
Gwjvw
Feb 18, 2010 09:57 PM
deadreckoning
Shovelhead
Jan 19, 2009 04:28 PM
