Clutch Questions
Old Sep 20, 2019 | 04:00 PM
jfcroni44's Avatar
jfcroni44
Default Clutch Questions
I have my basket case running well, but now I'm having some clutch release issues. I have followed the book on adjustments, but when pulling the lever, it not fully disengaging.
When pulling the clutch lever, how much deflection should I see at the pressure plate? 1/16 or so? This is a wet clutch setup.
Release lever is set to 1/2" from starter as detailed in book. I believe this gives the best position for the release lever fork. The lock nuts are set to 1" to 1 1/32".
New cable and Bikers Choice lever.
Old Sep 20, 2019 | 07:27 PM
johnjzjz's Avatar
johnjzjz
you could have a bad throwout bearing its in the kicker cover
BUT - the clutch arm is correct at 1/2 inch BUT is the screw loose at the 1/2 inch when you back it off to the 1/2 inch - the lever should be able to move to the starter easy - does it
Old Sep 21, 2019 | 09:22 AM
jfcroni44's Avatar
jfcroni44
I pulled the kicker cover during the restore. The T/O looked OK. I'll double check the other two BUT's. Thanks.
Old Sep 21, 2019 | 12:28 PM
jfcroni44's Avatar
jfcroni44
(the lever should be able to move to the starter easy - does it) Right now, with the cable on and locked with the lock nut, the release lever is 1/2 from the starter. It does not move any closer to it. When pulling the lever, I get the full motion of the lever travel, and the release lever does not hit the case... stopping the the motion. Not sure what you mean that the lever should be able to move to the starter easy
Old Sep 21, 2019 | 04:09 PM
johnjzjz's Avatar
johnjzjz
if incorrect parts are in it as I am not looking at what you are - to re do the entire adjustment the arm at 1/2 inch off the starter should have free play back to the starter
then you pull the bar lever
then you adjust the screw to till the lever is at the clamp
then hold that position with the screw and tighten the nut
what do you have NOW
Old Sep 21, 2019 | 07:29 PM
john lee's Avatar
john lee
thats correct
Old Sep 23, 2019 | 06:58 PM
jfcroni44's Avatar
jfcroni44
I started from scratch.... Pulled the derby cover and re-adjusted the pressure plate springs from 31/32" to 1 1/32nd" and I got down-right precise with it.. I re-adjusted the release lever so the release fingers on the release shaft were in the best position to start pushing on the T/O bearing to give it the most leverage and furthest movement when pulling the clutch lever. I adjusted the cable and bounced back to the rod adjustment a time or two... now all is well. I took the bike for a ride and I have minimal - to no creep, while in gear with the clutch pulled... Happiness is....a warm bike and good clutch.
Old Sep 23, 2019 | 07:10 PM
johnjzjz's Avatar
johnjzjz
turn the screw just 1/2 the loose distance again and re adjust
Old Sep 24, 2019 | 08:08 AM
FL54's Avatar
FL54
Similar to Mousetrap adjustment. Loosen everything up, start from scratch and follow the manual.
paid4c4
2014-2024 Touring Models
Apr 13, 2018 10:23 AM
Kwest88
May 18, 2015 01:00 PM
Voldemort
Aug 15, 2013 06:08 PM
Bankrupt
Exhaust System Topics
Apr 11, 2011 05:36 PM
sundancewind
Sep 25, 2007 08:50 PM
