Dry Clutch Problem.
Old Dec 11, 2019 | 06:32 PM
ArloCooper's Avatar
ArloCooper
4th Gear
Unhappy Dry Clutch Problem.
Hey guys,
Just after abit of advice.
Bought a Shovel with a blown gearbox (1976 FX) its got a dry clutch, with an open primary, no starter. I've bought a second hand 4 speed and mounted it. Swapped all the bits over clutch kicker and all, (bike came with no clutch cable) installed a clutch cable (supposedly oe part, length and all) but I cannot get the clutch to function at all. If the springs are set and the clutch adjustment screw is screwed all the way in till the clutch arm is pushed all the way back then backed off half a turn. Pulling in on the clutch arm doesn't give any movement what so ever. There must be something I am doing wrong. Inside the kicker cover the lever and all seems to be all aligned to the clutch rod. I believe all the clutch plates are in the correct way. Spring measurement should be pretty correct although I have a weird putter pressure plate different to most. But even then shouldn't there be a tiny bit of movement like the clutch is semi functioning? Just an fyi that the clutch was working fine when I pulled it off. Even though the gearbox was cooked the clutch still functioned.
Please any info would be highly appreaciated. Ive been going at this for a few months haha. I also have a workshop manual and it has hardly any info on this.
Thank you for your time,
Arlo.
Old Dec 11, 2019 | 07:21 PM
Joe12RK's Avatar
Joe12RK
usually the first adjustment is to get the clutch arm 5/8" from the starter so the lever inside the kicker cover is correctly aligned with the throw-out bearing. without a starter, IDK how you would verify that, but it's important, because the other adjustments work off that.
not a lot of help but that's all I got. hopefully one or two of the experts will answer soon.
Old Dec 11, 2019 | 09:06 PM
johnjzjz's Avatar
johnjzjz
the throw out bearing might have turned and not in the slot and now your pushing on the bell sideways
pull the kicker cover off and post up pictures if you need to many on here can help
Old Dec 14, 2019 | 07:42 PM
Bumpandrun's Avatar
Bumpandrun
What John says....happens a lot. Just pull kicker cover like was said and check it all out.Plus side it will give you a better understanding of how it all works and you will,eventually have to go in there...chit happens
Old Dec 16, 2019 | 07:24 PM
1981 suprglide's Avatar
1981 suprglide
wow you said a dry clutch is it a primo Rivera diaphragm clutch if so adjustment easy don't touch that cable just tighten her up and work with the middle of the clutch hub only you can do everything from there
Old Dec 16, 2019 | 07:33 PM
johnjzjz's Avatar
johnjzjz
only if your cable adjustment is correct to begin with
Old Dec 16, 2019 | 09:05 PM
Racepres's Avatar
Racepres
All Shovelhead clutches are effectively Dry... By Design... the Oil is drooled onto the chain [as stock] and sucked out at the back of the primary..
The same clutch works fine with a sealed primary..long as you only put enough oil in to get some on the chain!!
As stated...even in the Good book... the Lever must be at optimum Angle...really the Fingers against the Throwout Must be at the correct angle of attack...to get proper function... You must start with the Lever at the correct position...and then proceed.
Old Dec 17, 2019 | 08:19 AM
1981 suprglide
you are so right I remember now mine had what you call the sump system which sucked the oil from the primary back through the oil pump was not a good system put a screwing on the oil pump because of the metal particles from the chain
Rusty Axle
Shovelhead
17
Jul 7, 2021 05:20 PM
cc_Penguin
Oct 27, 2019 05:30 PM
lyndenjh
Shovelhead
21
Oct 10, 2017 10:58 PM
Cleetussnow
EVO
Feb 27, 2012 02:37 PM
Joshua
Apr 11, 2010 03:01 PM
