‘77 Shovel - Engine teardown
Old Mar 30, 2020 | 02:38 AM
Speeding Big Twin's Avatar
Speeding Big Twin
Thanks for clarifying the frame situation.
I can't tell the exact year of either case. I imagine the R-H case is 75 or later because 75 was the first model year to have the crankcase production number (CPN) inside the gear compartment. But it looks like the CPN was machined off that case, as mentioned earlier.
I suspect your left case is about mid-71 or later because I don’t see a boss for an engine number. (Even though the Shovel left case changed as of 1970 models there was a number boss in the casting for a short while after that.)
For future reference here’s a CPN inside the gear compartment of a 77 case.
And here’s the CPN under the matching 77 left case.
And from another 77 Shovel, here is an example of extra ID stamped at the rear of the cases. In this instance the letter is D but some other letters were also used.
Anything stamped on top of your cases near the holes for the rear engine mounting bolts? If nothing, is there any sign that something was removed? Photo?
Eric
Old Mar 30, 2020 | 06:28 AM
98hotrodfatboy's Avatar
98hotrodfatboy
WOW.... That's one "hot" motor... And I'm not talking power..... I'll bet the VIN is bogus..
Old Mar 30, 2020 | 11:08 AM
johnjzjz's Avatar
johnjzjz
I know guys who would bring it back holding an axe and talk very calm and explain you have a back hoe so no one will know
notop71
EVO
Mar 7, 2020 08:45 AM
Dirtyd61
Evo Era Parts
Dec 29, 2019 04:18 PM
sB43
EVO
Dec 25, 2019 01:32 PM
Parts Giant
Parts Giant
Mar 8, 2019 09:24 AM
cthowards
Apr 6, 2010 01:22 AM
