Starter gear/ bendix
Old Apr 21, 2020 | 06:29 AM
Sims 70flh's Avatar
Sims 70flh
1st Gear
Default Starter gear/ bendix
Hi there, i got a 1970 FLH and when using the e start all i can hear is spinning
Pretty sure the bendix needs replacing
Once i pull the primary off am i able to pull the starter shaft and bendix from the primary side without removing clutch basket etc and do i need to remove the starter motor?
any tips would be appreciated?
Old Apr 21, 2020 | 07:47 AM
johnjzjz's Avatar
johnjzjz
battery disconnect - pulled solenoid - outer pri - clutch and chains and sprockets off pull Bendix and shaft - new USA Bendix
we ould also pull the starter and the inner primary housing to replace the gaskets and o ring ( better yet install a james rubber replacement plate with the seal formed in it ) - replace that bearing in the cover - grease the gearing and new bearing -
Old Apr 21, 2020 | 08:27 AM
Racepres's Avatar
Racepres
Great... and while yer there...and If that Round Swingarm don't have 13 inch Shocks... the Housing is Probably already got a Hole Ground in it from the Chain... so that Plate won't do any good... otherwise... they work Nice..
Old Apr 21, 2020 | 04:50 PM
Sims 70flh's Avatar
Sims 70flh
1st Gear
Thanks appreciate the input, i was told yuo can remove the shaft without removing the clutch and sprockets but not sure how that would work
Old Apr 21, 2020 | 07:05 PM
johnjzjz's Avatar
johnjzjz
yea it can
oxygen and acetylene torches are your friend going in -- not so much going back together
arod6
May 13, 2016 07:46 AM
95 Ultra
EVO
Dec 16, 2012 08:03 PM
SHVLrules
Shovelhead
May 6, 2012 01:25 PM
calex3517
EVO
May 2, 2009 10:23 PM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
