Ignition coil v fire II
I replaced the plugs and grounded them out to check the spark......was not impressed with yellowish spark, expected to see blue.
Vodoo has a replacement for the 31609-80 that is specifically made for the V fire II ignition that I have and it is made in USA. Primary is 4.0 ohms and the bible calls for 3.3-3.7 ohms.
Close enough? Dynatec has the DC6-1 and primary is 3.0 ohms. As I understand, the lower the primary resistance the physically hotter the coil will get so I think 4.0 Ohms would be a better choice?
the only number your looking for is across the two terminals for cross/over OHMs - get a 3 OHM coil - dont re jet the carb it thought the charging system was dead as well as the battery as the coil your using was around 10,000 volts at best using a 5 OHM in a 3 ohm system
ignition. The HD coil 31609-80 I have is 3.5 ohms, read across the two terminals.
Troubleshooting today I found one of my new 8.8 accel wires wires open. The wires were new last year and the end must have started to fail when I replaced the coil last year.
I hear you John, here are the descriptions for both 3 and 4 ohm coil:
Andover Black/Green Voodoo Dual-Fire High Power Ignition Coil - 3.0 OHM - 16064
- These high voltage USA made coils are available in 45,000 Volt Voodoo versions
- These coils bolt into OE position
- High voltage coils help increase performance, fuel economy and offer easier starting
- Replaces HD# 31614-83 and 31620-88A
FITS: Big Twin models 1984/1999 and Sportster models 1985/2003 with V-Fire III electronic ignitions.
Here is the description for the 4.0
Andover Black/Green Voodoo Dual-Fire High Power Ignition Coil - 4.0 OHM - 16062
- Replaces HD# 31609-80
FITS: All Shovelhead models 1980/1984 and Sportster models 1980/1982 with V-Fire II electronic ignitions and Sportster models 1983/1984 with V-Fire III ignitions. Specifications
I took the boots off and found the end that goes into the coil to have a problem. On the good end that goes on the spark plug I could see the insulation was cut back and the carbon core was tucked under the metal clamp when it was crimped. On the coil end, the carbon core was not tucked under and was almost flush with the insulation. I got carbon dust all over my fingers when I pried the crimp open so it seems that the core may have been laying against the metal making poor contact and getting blown apart as a result. It was never tucked under.
I cut back the insulation leaving the core about 1" long and tucked it under the clamp when I re-crimped it. I took an Ohms reading 4.7 K ohms, with in 10" wire spec of 25-58K.
Put everything back together and she fired up 1st crank!! Took her for a 10 mile run and it ran like a champ....all is good for now.
Lesson learned.....be very careful with spark plug wires. I had no idea that the ends were just crimped around the very pliable jacket of the wire.
