Leaking Primary
Old Mar 7, 2021 | 07:32 AM
DrDirty's Avatar
DrDirty
Originally Posted by Lowoilpressure
I tried like hell to get the clutch hub off the shaft. HAd the left handed nut off the shaft. I really was beating the hell out of it. Used an impact wrench on the hub puller too. I can't explain why it's stuck so bad.
I fired the bike up yesterday for the first time this year. Fired right up. I'll get it into my shop soon and try again. I'll start a thread when I do because I need help on this one.
Tom
Its been 25 years since I pulled one but I don't remember it being that hard. Did you try heat on the clutch hub?
Old Mar 7, 2021 | 11:23 AM
Bmp72's Avatar
Bmp72
+1, was thinking the same thing, try heat. Maybe it is locktited on there...
I had mine off this winter, it does take quite some force with the puller but nowhere near an impact wrench
Old Mar 7, 2021 | 12:48 PM
Lowoilpressure's Avatar
Lowoilpressure
Heat is the only 'tool' I haven't tried yet. I'm telling you, it's on there.
I want to get a little riding in this spring, like maybe 100 miles and then I'll take it apart again. The bike is amazing except the leak.
Tom
Old Mar 7, 2021 | 01:27 PM
johnjzjz's Avatar
johnjzjz
We bring the tool up tight not stupid tight - then with a brass hammer give it a wack it will pop off - i use a 3/8 electric impact on the tool
Old Mar 7, 2021 | 01:31 PM
DrDirty's Avatar
DrDirty
I think I may have located the leak. I ran it again on the lift and this time I put it in gear so everything was moving. Not a single drip from the rear of the primary but I saw a couple drops coming off the lift and found a drip between the primary and engine case. I guess the oil has been following the frame rail and dripping off further back.
Since I can't ride it right now I can't determine if there is another leak but the primary has to come off anyway so I will replace all the seals.
This is probably a good time to isolate the primary too.
These old girls will keep you busy.
Old Mar 7, 2021 | 01:35 PM
DrDirty's Avatar
DrDirty
Thanks for the tip John. I have a 1/2" cordless impact that should do the trick.
I need to get my front brake back together before I start on the primary but that will be my next project.
Old Mar 11, 2021 | 11:53 AM
HDsvito's Avatar
HDsvito
6th Gear
Hi it is probably also worth to check the sprocket side of the main gear. There is the main shaft oil seal that could leak. I have noticed that earlier.
Old Mar 11, 2021 | 02:23 PM
john lee's Avatar
john lee
isolate the primary why ? you changing to belt ?
Old Mar 11, 2021 | 03:12 PM
DrDirty's Avatar
DrDirty
No belt for me. Just want to eliminate the primary oil going back to the engine.
RistoRap
Jul 17, 2015 07:21 PM
iflybyu
May 16, 2015 06:38 PM
LisaLowRider
Aug 12, 2013 05:13 PM
Ultrascott
Aug 3, 2012 04:40 AM
motox285
Aug 14, 2010 05:22 PM
