Light Circuit Dropped Voltage
Also check across that breaker for resistance (no power) and for voltage drop across the posts under load. (power connected, lights on).
Should be basically zero ohms across it with no power and no more than .1 - .3 volts drop under load.
Breaker was at 0 ohm with no power. Voltage drop at load was -.2.
At restart after all that I did have a slight increase in voltage with lights on, but only from 12.0ish to 12.5ish
Forget lights off. Always run them on. Could be battery. It will affect voltage regulator but usually, its then too high.
If alternator resistance and AC out put is OK, you need to check resistance on all thur lines to lights.
I would have to do too much homework to verify wire size. I assume that is correct. Interesting, I have converted a couple 6 volt system to 12. I had one person tell me a wire can be too big. Not sure within reason if that's true. You don't want a 2 gage battery wire going to a tail light but would a #10 matter? Got me.
Thanks all. I really appreciate the expertise.
You said you rode recently and it was down to 11 when you got back was my reason for thinking it was a charging problem. Remember, just because a battery is new doesn't mean it's good. You wouldn't believe how often a bad one turns up on here.
You can take to any "fast food" parts store and have it load tested for free. It needs to be fully charged for an accurate load test. I highly recommend you do that next, before you panic chasing an issue that may not exist. Do that and see what you have and one of us can walk you thru the stator check if the battery isn't defective.
Run it up to around 1500 - 2500 RPM. If the voltage does NOT go to 13.8-14.2 you are not charging.
If it does go that high, have your battery load tested (as has been mentioned).
If it does not go that high, its regulator / stator problem. (seems you have checked the wiring in this area).
I should mention I tested the charging system as well last night. I had no reaction to resistance testing from each regulator pin to ground. With the probes in the stator female plugs I got about 50 AC volts at around 2000 rpms.
As suggested I guess the next step is replacing the regulator anyway. Frustrating since I maybe have 100 miles on the current one. But that's what I get for riding a classic I suppose. If there are any other stones I haven't turned over I'm all ears. Thanks much.
USA regulators are available from Mid USA motorcycle and worth the wait
