Light Circuit Dropped Voltage
I checked my battery after riding last night and sure enough it is down to abt 11v. It's a newer Drag Specialties high output battery. The light isn't dim when it is on, but I could tell by the sluggish starter (after it wouldn't kick over) that the battery was low.
I have basically this same wiring setup, other than I don't run a horn or dimmer, and I have a Dyna2000i instead of a crane ignition.
I've checked continuity of the light fixtures to the frame and ground posts. Everything is under 0.3 ohms, usually 0.1. So taillight, headlight, brake switch, 30A breaker.
I'm running 16ga wire for the connections, larger for power from Battery to breaker, starter, and ground.
I'm not sure where else to start looking for such a big draw on the circuit. I was going to pull off the ignition switch next, since its just a cheap V-Twin one and see if maybe something is loose or pinched.
Thanks for the help. Here's a picture of my shovelhead as it sits now.
Here's a long, but otherwise excellent write up on steps to check it throughly;
https://www.hdforums.com/forum/evo-c...ng-system.html
I'll go through the steps in the link and see if I can get more info to work with. I certainly could've done something wrong on the install to keep it from working right. Just strange that a newer charging system will work so well otherwise.
i don't have any accessories or oddball attachments. the only deviation from the diagram above (which is the same setup I followed on a '96 evo chopper project and it's ran fine that way for 6 years now) is that I use a basic momentary switch mounted below the battery box as a starter button.
Thanks, really looking forward to sorting this out before the weather here in WA gets nice.
Also check across that breaker for resistance (no power) and for voltage drop across the posts under load. (power connected, lights on).
Should be basically zero ohms across it with no power and no more than .1 - .3 volts drop under load.
Forget lights off. Always run them on. Could be battery. It will affect voltage regulator but usually, its then too high.
If alternator resistance and AC out put is OK, you need to check resistance on all thur lines to lights.
I would have to do too much homework to verify wire size. I assume that is correct. Interesting, I have converted a couple 6 volt system to 12. I had one person tell me a wire can be too big. Not sure within reason if that's true. You don't want a 2 gage battery wire going to a tail light but would a #10 matter? Got me.
I would never wire one that way.
