oil pump
Old Apr 7, 2021 | 04:27 PM
john lee's Avatar
john lee
Default oil pump
whats the best way to reseat the check ball without removing the pump.first press of the starter started the bike after sitting 8mths but puked oil out the breather. whats involved in removing the pump apart from disconecting the hoses and removing the bolts thanks all
Old Apr 7, 2021 | 04:42 PM
rickss69's Avatar
rickss69
Pretty good overview of a pump here...
Old Apr 7, 2021 | 05:02 PM
johnjzjz's Avatar
johnjzjz
Real light on info 4 different pumps were in the shovels while they all remove the same way and opinions vary as to what really works - while mike is a good guy your asking different questions
correct way to do what your looking to do - remove the push rods then cam cover then the camshaft and breather valve that your looking for deep scores in the block - oil lines and oil pump bolts and the clip in the cam cover that holds the drive gear - then slide the oil pump out and dissasemble completly -we use new springs and the one 3/8 ball
then 2 thing can happen we have a tool that reseats the ball seat but we have had luck with valve grinding compound lapping the pumps seat with a 3/8 ball end pushrod do it 3 times and wash it each time - new gaskets and re assemble — must be spotless you used valve grinding compound - did i say spotless
Old Apr 7, 2021 | 11:23 PM
fergerburger's Avatar
fergerburger
whaever you do - do not smash a 3/8" ball bearing into the seat with a hammer - you will crack the seat - to lap the seat you will need to remove the pump - JZ knows that clover lapping compound is the best bet to get the seat finished - you can hot glue a 3/8 ball onto a metal rod - add some clover - lap back and forth - this will work - forget that seat cutter - it will leave a rough chamfer and you'll need to lap it anyway - maybe some guys can do it with the cutter - I have also used a ball mill to clean up the seat - and I have used metal inserts pressed into the land - just beware that the seat could be cracked and then you need a new pump or an insert pressed into the pump
Old Apr 8, 2021 | 03:24 PM
johnjzjz's Avatar
johnjzjz
Ferg i do not use a seat cutter it destroys the pump i use this BUT i said BUT you need someone to show you if your unconscious and do not get its a finesse
Old Apr 8, 2021 | 03:30 PM
johnjzjz's Avatar
johnjzjz
What is does is re shapes the seat and a skinnie painters brush and dykem lacquer thinner and to clean you can like a valve seat make it wide enough to actually do the job intended - and lapping it and watching the circle come into round again - but again with no experience or being shown you could destroy a OEM original re usable iron or first edition alloy oil pump
pilot1996
Oil Archive (no new posts)
Nov 14, 2021 07:05 AM
john lee
Shovelhead
22
Dec 5, 2019 03:59 PM
fergerburger
Shovelhead
15
Mar 29, 2018 09:19 AM
Bluto 67
Shovelhead
Jul 24, 2009 05:59 PM
degr90
Shovelhead
Jan 16, 2006 06:06 AM
