oil pump
Old Nov 28, 2019 | 03:26 PM
john lee's Avatar
john lee
Default oil pump
i took my shovel for a ride after sitting for 5 months and oil dripped out the breather meaning oil seeped past the check ball.whats the best way to reseat it without taking off the pump. thanks
Old Nov 28, 2019 | 03:57 PM
Hoginedgewood's Avatar
Hoginedgewood
I tried the extra ball being beat into the bottom of the pump. Didn’t work. So I put a shutoff on the hose that feeds the pump. I hang my key on it.
Old Nov 28, 2019 | 04:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It sat 5 months and oil dripped out the breather.
Wipe the oil off and don`t worry about it, unless it barfs oil after sitting for a short period.
Old Nov 28, 2019 | 08:44 PM
johnjzjz's Avatar
johnjzjz
we see all different things happen with the ball - I have a tool to re seat the pump body's seat - yea it works most of the time - when a pump is off and going back on we made a tool to lap the seat using a 3/8 ball end push rod - again that also works most of the time
that brings us to hitting the ball to re seat it - I broke a couple of pumps before any of the tools were invented hitting it too hard - and its not done in a real shop today they just replace the oil pump -- well that is also not written in stone to work every time
as said wipe its tinkle and forgetaboutit
Old Nov 28, 2019 | 08:52 PM
TommyShovels's Avatar
TommyShovels
You can take an old ball, if its smooth, preferably a new one - weld a rod to it then stick it in the seat and lap it like you would valves.
Old Nov 28, 2019 | 09:02 PM
Hoginedgewood
ive heard an evo pushrod works
Old Dec 1, 2019 | 02:57 PM
badgerfarm's Avatar
badgerfarm
I redid the ball seat on mine with the pushrod trick. It works.
Old Dec 1, 2019 | 03:20 PM
john lee's Avatar
john lee
any valve lapping paste used. thanks
Old Dec 1, 2019 | 03:39 PM
johnjzjz's Avatar
johnjzjz
maybe I will get lucky again with this answer
think about putting valve grinding compound in the oil pump that's installed and then - how would you propose you were going to clean it out
Old Dec 1, 2019 | 05:09 PM
badgerfarm's Avatar
badgerfarm
I didn't use any grinding compound just the tip of the pushrod but I did bead blast the tip to give it some texture.
