From Google and YouTube they seem to work fine. Might be worth it if for nothing more than spare parts...they usually come with an assortment of jets and whatnot.
I have bought at least 10 china carbs for golf carts mini bikes and honda scooters every one worked as if they was a real carb
i just ordered one 49.00 bucks and i need a bowl for a real s&s so if its junk the s&s bowl is 65 bucks i will be 20 bucks to the good if it works i will order a few for an alternative
Anybody tried one of those Chinese JIK Super E carbs I am seeing on e-bay? For $50 I wouldn't expect too much.
hello shovelnik,
have you thought of maybe going OEM Keihin ? i have bought 3 OEM Carbs & have had no problems at all with them, 2 were double pull throttle & 1 is single pull big TIP :
buy ones that have NOT had the mixture screw plumb taken off . . . all three of mine were plug & play ! really just check them out & replace any O ring gaskets & maybe the accelerator pump diaphragm . . . heres an example of one that available here in Germany . . .the last one i got was a 2 pull from MachIVMotors in the USA for only 52$ plus shipping . . .
single pull throttle for sale on ebay.de . . .
my last 2 pull throttle , both just plug & play no guessing on wich jets or other tuning issues . . .
