The rocker pins have holes to allow the oil to pass from one side of each rocker box to the other, and also an oil through the pin to lube the rocker itself.
Does it matter if the holes line up? there is a channel in the pin that the pumped oil goes around to reach the two holes in the end of each pin.
I was wondering if its best to line these up a certain way.
Thanks
Something I have never stressed over..as the "ring" you speak of carries oil from port to port, regardless
