OEM rear Sprocket offset
Old Feb 22, 2022 | 09:10 AM
Redrodyankneck's Avatar
Redrodyankneck
Default OEM rear Sprocket offset
I wanted to replace the rear sprocket 48T on my 83 FXR and the 51T rear sprocket on my 81 FXWG.
What is the OEM offset for each? Manual has no offset numbers. I'm getting some conflicting info from a vendor I normally buy from.
Both my sprockets are dished( no spacers) and from bolt mounting surface to outer edge of sprockets I get aprox 1/4" for 81 FXWG and aprox 1/2" for 83 FXR
Old Feb 22, 2022 | 10:01 AM
Joe12RK's Avatar
Joe12RK
If your chains are aligned, you have your answer right there. Am I missing something?
Old Feb 22, 2022 | 06:20 PM
Redrodyankneck
Yes, what is the standard offset specified by Harley for each model? Some vendors have dimensions that differ from mine.
Old Feb 22, 2022 | 07:34 PM
Joe12RK's Avatar
Joe12RK
This dimension on my 82 FXR is 1/2"
Old Feb 23, 2022 | 06:40 AM
johnjzjz's Avatar
johnjzjz
I will look it up but i believe one is .500 the other is 9MM or so
Old Feb 23, 2022 | 07:23 AM
Redrodyankneck
Thanks Joe. When I was attempting to order new sprockets I was given several different offset from vendors.
Old Feb 23, 2022 | 07:25 AM
Redrodyankneck
Cool, I'm on standby!
Old Feb 23, 2022 | 09:52 AM
magnum45pete's Avatar
magnum45pete
on my shovels, I had an off set sprocket about 1/4 inch out,
but I recently fitted a rear 'Wagon Wheel' with the round spokes off of a 2004 Road King I think.
after spacing the wheel centered in the frame, I needed a flat conversion sprocket to line the chain up right,..
I think until the fat wheel Harleys came out in the last 15-20 years, that most rear wheels from the late 30's to the 2000's are within a few thou of each other for the major measurements such as disc, sprocket, pully fitment as the factory didnt like change as it cost money to re-tool,
in your case I dont have a definative answer, as parts did often change for whatever factory reason,
so if I were in your shoes, I'd mount the wheel without spacers, center the rubber, then see where the chain wants to be & get the sprocket that is the best either flat, dished out or dished in.... remember, the Factory did at times throw any old thing on them just to get them out the door.
streamliner
Mar 3, 2021 06:22 PM
Zdollar
Sep 7, 2020 01:13 AM
zenpirate
Wheels/Tires
Nov 14, 2010 01:01 PM
McC.Tan
VRSC Models
May 28, 2008 06:52 PM
