75 basket case build
Old Jul 4, 2022 | 12:39 PM
Gela's Avatar
Gela
And I know pictures are good so here are a few from a 69 flh that I rebuilt. When I got the bike the pistons and clutch's were stuck and the brake fluid had turned solid like dirt. It had been chained to a tree for at least 7 years and had paint splashed on both sides. rode it from NC to Sturgis early 90's
Old Jul 4, 2022 | 12:50 PM
Gela's Avatar
Gela
These are the other bolts I haven't figured out yet. 2 have a d shaped washer that's curved a little. 2 have stepped washers . And one bolt with a castle nut.
This bike was wrecked and the front end has been replaced. The castle nut and bolt went to the other front end??
And from searching threads here it seems like tourqe specs should be about 150-160 for compensator and 70-80 for nut for clutch hub , that sound right?
Old Jul 4, 2022 | 01:51 PM
Joe12RK's Avatar
Joe12RK
Middle set are foot peg pivot bolts and spring washers. Bottom looks like rear disk brake stay bolt. Can't ID the top ones.
Old Jul 4, 2022 | 03:04 PM
carlgrover's Avatar
carlgrover
If you keep the bolts, nuts etc with the part, they are still in the way.
When disassembling a machine, each part should be tagged or bagged, slow but makes re assembly much easier.
That is a really good idea. I use small bowls for hardware and I also screw the nuts/bolts right back where they go if they don't get in the way.
carl
Old Jul 4, 2022 | 03:43 PM
magnum45pete's Avatar
magnum45pete
the top bolts, or at least the stepped washers on the top bolt's, are usually found on cheap after market foot pegs that clamp on with a 'U' clamp & the stepped washer bites in the frame or crash bars to stop them spinning on ya,... not a factory Harley part...
Old Jul 4, 2022 | 04:00 PM
Johnny jonjon's Avatar
Johnny jonjon
Not trying to offend you but I’ve talked to several guys with broken engine mounts after a rebuild and the first thing I ask is “did you shim engine to frame In Accordance With manual ? I always get the wtf look and a reply that lets me know they never did. If you are now having a WTF experience please stop and read manual.
Old Jul 4, 2022 | 04:45 PM
john lee's Avatar
john lee
carl
number 1 rule
Old Jul 4, 2022 | 10:11 PM
TwiZted Biker's Avatar
TwiZted Biker
Short one with the castle nut is the rear disc brake anchor strap bolt for the square swingarm, goes to the tab on the bottom of the swingarm just forward of the shock mount.
Top ones look like the bolt & wedge washers some aftermarket U clamps came with for the frame tubes, usually 2 wedges per.
Joe called the middle bolts.
Old Jul 4, 2022 | 10:14 PM
TwiZted Biker
You get points for knowing that, not many do, I set & shim engine and trans, makes a serious difference vibration reduction and stuff fitting correctly.
Old Jul 4, 2022 | 10:41 PM
Gela's Avatar
Gela
I did have to shim one of the front motor bolts 6 thousands.
I usually use ziplock bags for bolts. A few years ago I learned if you let sunlight shine through a window on the bags for an extended period the ziplock bag will disenagrate..
Thanks for the help.
