Gearbox leak
Old Aug 22, 2022 | 01:52 AM
stephtell's Avatar
stephtell
Default Gearbox leak
Goodmorning!
Seems my gearbox, 4 speed manual on 76' FLH, is leaking from the righthandside, in between the gearbox and the rhs cover.
Can I just unbolt the cover, replace the gasket with a proper James item, and refit the cover, or is there more involved?
Old Aug 22, 2022 | 06:05 AM
johnjzjz's Avatar
johnjzjz
The exhaust is in the way but doable - derby cover off you need to re adjust the clutch center screw and hand lever cable
look close to be sure the center floor of the case is not cracked - someone may have used a bolt too long - this will make you think the cover is leaking
if it is we have had luck with JB weld on the floor and a shorter 3/8X16 bolt
Old Aug 22, 2022 | 06:10 AM
stephtell's Avatar
stephtell
Excellent advice, thanks! The oil from the box is actually on top of the frametube underneath the cover, hence me thinking it is probably the gasket...will have a good look around!
Old Aug 22, 2022 | 09:55 AM
Racepres's Avatar
Racepres
Look critically at the vent/bolt.. Overfill or Excess water can come out the vent
Old Aug 22, 2022 | 01:41 PM
stephtell's Avatar
stephtell
Thanks, will investigate!
engineer40
May 10, 2024 07:59 PM
Fblo1690
EVO
21
Jun 16, 2021 11:19 AM
Monkeybutt2000
13
Oct 28, 2012 11:51 AM
mrmikey32
Apr 27, 2012 09:36 AM
DPete
Jan 20, 2009 09:02 AM
