Difference between late & early 79 Shovelhead?
Old Aug 19, 2007 | 01:14 PM
redzonecj's Avatar
redzonecj
Stage II
Default Difference between late & early 79 Shovelhead?
Hi, I'm new here. I'm hoping someone will be able to helpanswer a question. We have a 1979 FLH Shovelhead we're in the process of restoring. When searching for parts I often run across descriptions which state the part is either for a late 79 SH or an early 79 SH. Can anyone tell me how I might be able to determine if our SH is a late or early 79 model?
Thanks for any help.
Old Aug 19, 2007 | 01:24 PM
panz4ever's Avatar
panz4ever
Default RE: Difference between late & early 79 Shovelhead?
redzone..herez production numbers for the FLH 74 and FLH 80. Might help a little.
FLH 74 ... 2A 20154 H9 (starting) 2A 76951 H9 (ending)
FLH 80 ... 3G 20161 H9 (starting) 3G 80437 H9 (ending)
Old Aug 19, 2007 | 01:33 PM
redzonecj's Avatar
redzonecj
Stage II
Thanks for the reply, but honestly I'm lost as to what those numbers indicate. This is my husbands bike, he's PC timid...won't post. Basically what he's wanting to know is how to determine which chrome hwy bars he needs. Found two differentbars stating they're for a 79 SH...one states it fits the early 79 SH, other says late 79 SH.He's not sure whichset will fit his frame...early or late model 79.
I've searched the net, read tons of Harley specs...can't find anything relating to the differences between late & early 79 SH, or how to determine which we have.
I do know ours is the FLH 80, haha.
Old Aug 19, 2007 | 05:29 PM
kiwidave2's Avatar
kiwidave2
there is one significant difference that year.
In mid-79 came the arrival of the rotary-top four-speed gearbox.
Also known as the turtle top, the cow pie, the turret top.
It replaced the ratchet-top mid-year.
I can't think of ANY frame changes that year.....but if those bars are what we over here call crash bars,front and rear to protect the engine/primary, I can just about see how the rear ones might take on a different fitting to allow for the new tranny. But I am guessing at that, don't ride an FLH..
regards from the UK
Old Aug 19, 2007 | 05:42 PM
ATM67's Avatar
ATM67
redzone,
I recently went through this myself. I have an early '78. Like you, I didn't know there was a mid production year change until I had bought it. I learned there was a difference when I started looking for service manuals. The service manuals are for 1970 through Early 1978 and then Late 1978 through 1980. That makes me wonder if there was an error in the listing of hwy bars you are looking at. That not withstanding, here is a link to a post that tells how to read your VIN -- https://www.hdforums.com/m_327424/tm.htm. The VIN can be found on the front of your frame and on your engine crank case. There is a third location where it can be found, but I am not sure where that is. Those numbers will tell you what year and model yours started as. Mine started life as a '78 FXE and a previous owner converted it to look like an FLH. To find out whether I have an early '78 or late '78, I had to look for the crank case number. It is found on either side on the underside of the crank case on the front. Look at the very last post on the thread (https://www.hdforums.com/m_1852591/tm.htm) for how to read the crank case number. I hope this will help you.
Old Aug 19, 2007 | 09:43 PM
panz4ever's Avatar
panz4ever
redzone..the numbering above applies to your vin system. Here is an even more exact way to determine when your bike came off the line...
Starting in 1975 HD changed their numbering process on the lower crankcase numbers, The new procedure utilizes the Julian date. (The Julian date uses all 365 days of the year. Jan 1 = 001; December 31 = 365)
Your FLH crankcase numbers should read something like this 1 79 - 001 001. 1 = FLH; 79 = year model; 001 = Julian date; 001 = sequential unit produced that day.
So, while you may not be able to determine how many units of your particular model were produced that day, the Julian date will give you exactly what day (and month from the Juliane date) your bike was made.
Old Aug 20, 2007 | 06:03 AM
JAMES2's Avatar
JAMES2
I have been there, early or late production runs, The only true thing from the factory back then was, "Use what ever parts are still on the shelf." Vin #'s help, but the OG parts are the best reference, take'm with ya if ya gott'm!
Old Aug 30, 2007 | 11:02 AM
Hippy43's Avatar
Hippy43
fast and simple. From what I was told, early `78 still had points, 78 1/2 up went to electronic ignition....
Old Sep 13, 2007 | 05:04 PM
funlaker's Avatar
funlaker
Stage I
I may be off here, but didn't early '79 have the Wagnermaster cylinder and late '79 have Kelsey-Hayes? That might explain the difference in guards.
FL54
Shovelhead
Mar 1, 2024 09:03 PM
Curated Content Editor
Mar 2, 2021 01:32 PM
john1dup
Shovelhead
Nov 7, 2012 05:14 AM
bbsbase
May 20, 2008 05:49 AM
sapperw5
Apr 9, 2007 08:42 PM
